Question about Samsung MW5351G Microwave Oven
Flickering lights Most of the lights in the house flicker when appliances turn on and off. The problem seems to be getting worse. I noticed the light in the kitchen actually glows brighter when I turn on a toaster oven or coffee pot and dims when they are turned off. What can cause this?
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Flickering light on kitchenaid microwave khhc2090sss
If you're referring to the cavity light, it's possible the bulb is just loose in its socket. The cover has to be removed to access the bulb.
Nov 04, 2017 | KitchenAid Microwave Ovens
How do I stop light from flickering
Lamp has loosened from the base. Just screw it back into the base. Secure the lamp to the base with one wrap of clear scotch tape.
Sep 26, 2014 | Panasonic Microwave Ovens
Led lights flickering
It has nothing to do with the microwave. Unfortunately, it sounds like the LED bulbs are defective and should be replaced.
May 15, 2017 | Microwave Ovens
Frigidaire microwave not heating over the range
Hello
Try to cook something simple such as microwave popcorn. If the unit does not light up or turn on, check the outlet with another appliance to make sure the outlet is functioning correctly.
Check the fuses or circuit breakers in you house. If the outlet does not work after testing it with another appliance, try to plug the microwave in a different outlet.
Check the hinges and door hooks to make sure the door is closing properly. Look to see whether a small piece of food is clinging to the door, preventing it from closing all the way. Check the release mechanism and the rotating plate to make sure they can move freely as well.
Plug in the microwave and start it a the bag of microwave popcorn inside. If the lights go on but it is not producing heat, listen and try to hear whether the unit sounds the way it usually does. If it does not, there might be problems with the circuit board. This will need to be repaired by a certified Frigidaire professional.
Check the display that shows the time and power. If the display is flickering but it does not alter the operation of the microwave, it is not a problem. If, however, the lights flicker and your food is not heating, there may be a problem in the microwave cabinet.
Listen for buzzing sounds. If there is a buzzing sound and no heat is being produced, you may have to get a new magnetron, power diode, or high-voltage capacitor. These can be purchased from a Frigidaire retailer.
Look at the handle on the door. The most common complaint about all models of the Frigidaire microwave, according to Consumeraffairs.com, was cracked or broken door handles. Frigidaire will replace faulty handles while the oven is under warranty. In many cases, they will replace the handle even after the warranty expires for a "reasonable" amount of time.
Oct 04, 2011 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Microwave turntable works intermittenly - also no light
if you have on the key pad turn table on/off it may be the pad itself / I would ck the connections on the prosser . as the get film (correded ) you can use a spray cleanner for this . and it may correct the problem . flickering light may be the element and it may fail . (soon ) ****
Jan 09, 2010 | Samsung MW1030WA Microwave Oven
Flame flickers on the back of the cover when i switch on
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Dec 20, 2008 | Microwave Ovens
Partial Power Outage
This could be very dangerous.
I would first call your electric company and ask if they have any problems with their lines, etc. We recently had this problem at our home and it was in their circuits.
My mother in law had a similar problem and we caught it in time. In her house, several outlets showed extremely low voltage and the others showed extremely high voltage.
It turned out to be a bad neutral connection on the line going from the pole to the house. The electric company fixed it at no charge.
Also, you or someone you know should measure the voltages coming out of your outlets, or call an electrician right away.
You may have a loose circuit breaker or a bad connection somewhere your electrical panel or elsewhere in your neutral line.
This can lead to destruction of your appliances or even a fire, so please don't delay.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 16, 2008 | Hotpoint RVM1435 Microwave Oven
Microwave/small appliances do not turn on when plugged on to the power outlets on one wall.
What does "control panel has all fuses working" mean?
Are you saying you have an old-fashioned fuse panel in your house, instead of a modern circuit breaker panel?
If so, then I would suspect a bad connection in the panel.
If you indeed have breakers, a breaker can snap into the on and positions and still be bad.
Either problem sounds like it should be handled by a qualified electrician.
The power company or your insurance company would likely reimburse you for all or part of the electrician's bill, but you shoudl call first to be sure.
It's possible to have a faulty neutral connection in your wiring. That can lead to damage of several appliances and bulbs, and even pose a real fire or smoke hazard.
Please do not hesitate to get things fixed when you have home electrical problems!
Nov 04, 2007 | Samsung MW5351G Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
267 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
