Question about Epson STYLUS R230 InkJet Photo Printer
How can i solve my problem in my EPSON R230." this is the message that will display in my screen...: Parts inside your printer are at the end of their service life. and its ink and paper lights is blinking..tell me what should i do to fix it...plss..help me..
  • 700 Answers
Care to read this link
http://www.fixya.com/support/t1905683-r230_photo_printer_epson_stylus_sevice
http://www.fixya.com/support/t2015031-two_red_light_blinking
Posted on Sep 24, 2009
Testimonial: "thanks for the help..now i see why the red lights are blinking..thanks again..keep it up!:)"
  • fougzki Sep 24, 2009
    Or this also;
    http://tricks-collections.com/reset-epso...
    Just be sure that waste ink pad will not overflow.
Epson STYLUS R230 InkJet Photo Printer always blinking 2 red light how to solve this,,,
have you seen any dirty white foregin item inside the printer,you can also see CR motor upper side of ink westpad.
Apr 08, 2014 | Epson STYLUS R230 InkJet Photo Printer
"Parts inside your printer are
Probably need to have the ink pads replaced in your printer, I would call Epson for support.
Jun 16, 2011 | Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are near the end of their service life. See your printer documentation
Hi!
Click on this link for more information about that message. Click HERE.
Hope this helps.
Dec 13, 2010 | Epson STYLUS R230 InkJet Photo Printer
My printer, epson stylus R230, shows this message ' Parts inside your printer are at the end of their service life. See your printer documentation. ' How can I solve this problem?
You need to reset your printer. Google search for "indoreset for r230", that is the program that you can use to reset your printer. Or you can use the SSC Service Utility, just search for it in the net. You particularly need to reset the waste ink pad counter.
After you reset your printer, check the back of your r230, you will see there a small access cover with a screw. Unscrew it. Take a look inside and you will see a tube connected to the waste ink tank, try to disconnect it from the waste ink tank, carefully pulling it out the access window. Do not force it out completely, you will be able to pull out only about an inch of the tube. When the tube is out, get another tube (silicon or plastic) around 6 inches long would do (12 inches will be fine)that would fit in that tube you've just pulled out, then get an empty plastic bottle with a cover, puncture a hole in the cover and put the other end of the tube in that hole, that plastic bottle will be your new waste ink tank. You are doing all these so you don't have to dismantle your printer to remove and replace the waste ink pads inside.
After doing all these you can now use your printer again. You just need to empty the plastic bottle regularly. And when the time comes to reset your printer again, just use the program again and that's it.
Aug 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
Jan 29, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
How can i solve my problem in my EPSON R230." this is the message that will display in my screen...: Parts inside your printer are at the end of their service life. and its ink and paper lights is...
If you are using NON epson ink catridges? This is most likely your problem. I would recommend that you use only Epson products for your Epson printer. These "made in China" inks can ruin printers fast. If you are using only epson cartridges and this is still the case? You may have worn your printer out.
Hope this helps
Sep 24, 2009 | Epson Stylus C86 InkJet Printer
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
PART INSIDE YOUR PRINTER EPSON STAYLUS PHOTO R230 ARE AT THE END OF THEIR SERVICE LIFE SEE YOU PRINTER DOCUMENTATION
Parts inside your printer are near the end of their service life. See your printer documentation.
Mar 09, 2009 | Epson Stylus Photo R200 InkJet Printer
Service required for EPSON STYLUS R230
http://www.efillink.com/Support/HowToWasteInkDrainR200.html
Sep 25, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson STYLUS R230 InkJet Photo Printer Logo
308 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
