Question about Dell Dimension 2400 PC Desktop
Bad_pool_caller oxooooooc2 ox00000043 tried safe mode goes back to blue screen
    President:
  • 1,015 Answers
If you are unable to start the computer in safe mode then you will need to do a windows repair or re-install. You will need to use the installation discs that came with the pc or use the built-in restore menu if the pc has one. Some computers have a hard drive with a secondary partition that contains all the files to restore the computer back to factory setup. If your computer has this you will need to enter the menu from when the computer is first booted. You will see something that says hit F10 or F12 for setup. Then you can use that menu to restore your computer.
Posted on Sep 24, 2009
Unmountable boot volume
Please boot from bootable disc and repair the OS.
Mar 19, 2012 | Dell Computers & Internet
I'm getting a blue screen
What was the last thing you did before it happened??? installed a driver??? installed a software???, add a device??? this would help a lot to know...10000 things can make Windoze go in a blue screen... bad device, bad driver, corrupted MBR, bad software, bad memory, etc... try booting in safe mode to see if it works, if it does than it's a bad driver or software recently installed or a bad update that went wrong... if it does blue screen even in safe mode than it's a bad hardware, check all hardware... unplug all the hardware than plug back the hardware one by one to pinpoint which hardware is causing the problem... MEMORY, CD ROM, HARD DRIVE, WIRELESS CARD, etc...
Cheers!
Aug 22, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
My hp mini 1000 wont boot up. when i turn it on it goes right to a screen that asks how i want to start up windows ( safe mode, safe mode with networking, safe mode with command prompts, and start windows...
hi blinkgirl556
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
hope this helps
contact me for any updates
janc30
Feb 08, 2011 | HP Mini 1000 Netbook
Goes blue screen on start up. UNMOUNTABLE_BOOT_VOLUME Recommends starting in safe mode...will not start in safe mode either.
1.) Possible bad hard drive unit
2.) Possible bad cable/connector(s)
3.) Corrupt boot sector
You can try checking the cabling yourself. If that does nothing, then please consider hiring a local computer guy for assistance. (IMO: Avoid hiring technicians from big box stores.)
Dec 18, 2010 | Dell Inspiron Mini 10 Notebook
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
I have a eee pc 900hd and I keep getting the safe mode option
if a blue screen pops up with white writing theres something seriously wrong with your laptop a blue screen on a computer is the worst possible thing that could happen apart from the thing actually exploding and can be caused by a wide range of things, my suggestion would be to reinstall windows as it will basically give you brand new computer with no errors
Oct 30, 2009 | ASUS Eee PC 900HD Netbook
Lenovo X60 Laptop blue screen error wont boot up
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
Aug 27, 2009 | Lenovo ThinkPad X60 Notebook
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Dell Dimension 2400 PC Desktop Logo
804 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
