Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Installing XP on Nsew SATA(RAID)
I made a floppy disk with the RAID drivers,
Partitioned the hard disk using xp bootable cd,
formatted c:,
The setup copied all the need files but failed to copy 3 files,i.e. RAID driver files,
Now after rebooting Windows setup give an error before it starts.
I even checked that my floppy and floppy drive works perfectly.
Please help me!!! It's very urgent!!!
  • Mohd. Ismail Ansari
    Mohd. Ismail Ansari Dec 22, 2007
    It is the Microsoft Windows Xp Professional with Service Pack-2, as I have mentioned it a plenty of time in the problem itself.
  • 482 Answers
Is this windows 98?
Posted on Dec 16, 2007
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
Had a Blue Screen of death on my dell insipiron 530 desktop. i tried to repair the problem using the XP SP2 cd that came with the pc. now i'm getting an issue where I cannot see the hard disk. I really...
You may have a SATA hard drive. You will need to download the SATA drivers from Dell, put them on a floppy (if equipped) or burn to a CD. When Windows setup asks if you need a third party RAID controller (push "F6" I believe) load the drivers from the floppy or CD then continue with setup.
Oct 28, 2009 | Dell Inspiron 530s Desktop Computer...
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Aug 24, 2009 | Compaq Presario Notebook
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Blue screen comes
dear sir
for hp laptop they told that this laptopr only support windows vista but if u need to install windows xp u hav to make a sata or scsi drvier disk or cd for making cd u have to download a software call "Nlite" it's a softwaere to make a bootable cd with sata driver or u need to install from floppy u have to perchase or rented usb floppy drvier it's help u....:)
please vote
Jan 05, 2009 | Compaq Presario Notebook
How can I setup sata drivers using cd or dvd
Hi, I think the problem lies with your bios setting. Set the POST to first boot from the CD/DVD drive. If it is set to first boot from the CD/DVD drive, then the problem comes from the disk. It might not be a bootable disk. If you have any questions, please feel free to contact me. Thanks, Mike H
Nov 01, 2008 | ASUS P4S800D-X Motherboard
Sata hd, installing windows
Hi nveronika,
First things first. Find the name of you're SATA hard disk drive.
Please go to the manufacture's web site & download the floppy drive setup/utilities bootable software or creat a bootable CD from the manufactures site. Boot the system with their software & setup you're hard disk drive which will run in a DOS like window. (This should resovle the blue screen issue).
There are two different revision for the motherboard GA-M52l-S3
(Revisions, 2.0 uses the NVIDIA® GeForce 6100 / nForce 430 chipset):
& (Revision 1.0 which uses the NVIDIA® nForce 520LE Chipset):
Which is you're motherboard? Once you find the correct motherboard you can download the the needed software directly from the web site & create the correct floppy disk needed when pressing the F6 key during windows installation. If you still get an error message try another fresh floppy disk. (Corruption of files to a floppy usually mean the floppy drive is dirty or bad or the floppy disk is bad). It is also possible that the data cable to the floppy drive is loose or defective. Downloading directly from Gigabyte is suggested over using the CD.
Good luck nveronika!
Aug 30, 2008 | Intel Motherboard
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Mar 10, 2008 | ASUS K8S-MX Motherboard
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
