Question about Nikon AF 28mm f/3.5 PC-Nikkor Lens
The verticle rise slips down afetr being set
The vertical rise slips down after being set
    Sergeant:
  • 291 Answers
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
A verticle line in the picture "Top Down Dead
The symptom of your television is vertical problem.The problem is in vertical section of the board.Maybe theres a leak capacitor in vertical section.So try to replace the leak capacitor,the value is 100mf 35 v.You can identify the leak capacitor through visual checking if you have no knowledge in using tester to identify the leak capacitor.If you can see the capacitor have rounded shape at the top while the good capacitor is flated shape.
Aug 18, 2011 | Televison & Video
We have a 42L G30 and it has a verticle black line right down the middle of the screen. What's happening?
mostly the vertical deflection section of your tv is faulty (vertical output IC)
Dec 03, 2010 | LG 42LC2D 42 in. LCD HDTV
My husky pro vt631402aj verticle compressor won't stay running when compression rises
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Verticle black line
just on a whim I'd say you have vertical output IC circuits in distress.
can you say Warrenty :->
Jun 10, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
How do adjust verticle picture on Hitachi 46F510
You can adjust vertical height through the service menu, but i would recomed that you trouble shoot the vertical section as its probably a solder joint , leaky diode or something that is causing the problem. Often its bad solder at the vertical output IC itself that causes that sympton.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Nikon AF 28mm f/3.5 PC-Nikkor Lens Logo
69 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
