Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman Riding Mower
I have a Craftsman Riding mower LT1000, 42"cut, 2007 model. Leaking gas into the bowl where the carburator is. Gasket is sealing, it's not leaking out. I purchased a new "needle" and still leaking. I had asked them to order needle and seat, but the only ordered needle. do you think it could be the seat I need now? Have been trying to get this thing running so I can sell it. Seems this is the only issue left.
  • 437 Answers
When you replace the needle valve you always need to replace the seat. You also may have a bad float in the carburetor.
Posted on Sep 24, 2009
Testimonial: "Thank you so much!!!!"
Gas leak from bottom of carburator. backfier
If mower has been put up for winter and old gas left in gas tank it will drain to carburetor and the float will stick. This will let the gas flow out the float bowl. Remove float bowl and use carburetor cleaner to clean the valves and move the float up and down when it you get it clean the gas should flow float down and turn off when pushed up.
B. J.
Apr 09, 2014 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
Weedeater riding lawn mower made a loud pop now won't start
Sounds like you may have trash in your carburator bowl,to repair,empty gas tank or pinch line going to carb,there's a bowl under carb,has a screw holding it on,remove screw,be care,it also has a rubber gasket too,look in bowl to see trash,dump gas and clean with a paper towel and put back on.Also check your plug and air filter.You need a socket and a rachet to get screw off.
Aug 30, 2013 | Garden
I have a model # 917.289720 mower. It dies while cutting. Just did a tune up, fresh gas, new fuel fiter, spark plugs, air filter. HELP !
Take off carb and clean it assuring ports and orifices are not plugged, its starving for gas ! Main jet. Water bubbles in gas? in bowl? Drain.
Apr 10, 2013 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman ridding mower
Its not thing to do, but unplug the wires on switch and paper clip in the two slots.
Mar 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have used my mower 3 times and it is leaking gas out of the carborator faster than i can put it in.
You have water in your gas tank or gas in your carburator float or a needle valve that isn't seated correctly. First empty the gas in your fuel tank into a clear container. If their is water ,you will see it with the gas. Second remove the bowl from the bottom of the carburator careful of the gasket, check for water in the bowl, clean bowl. Carefully remove float and needle valve. Shake float, listen for liquid inside. Check tip of needle valve for damage or corrossion. These three examples should be one or all of your problem. Clean and reinstall all parts. Add fresh gas and you should be ok. GOOD LUCK.
Jun 30, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Carburator floods
Possibly the needle valve in the carb. fuel bowl.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an older craftsman 6speed 42"cut riding mower. When I try to start it, gas comes out of the exhaust and it will not start. Any suggestions?
Fuel is leaking past the float needle valve - ether because the float is stuck 'down', or because there is dirt on the seat, preventing it sealing.
Remove float bowl and float, clean needle valve & re-assemble. If it still leaks, you will have to replace the needle and seat.
May 08, 2010 | Garden
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
497 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
