Question about Sony Playstation 3 (PS3) Console
Time lag between Playstation 3 and LCD TV.
When my playstation 3 is hooked up to a normal television it works fine. However i recently purchased a flat panel LCD TV and have noticed that there is a lag between me pressing a button on the controller and actually seeing that particular button executed on the TV screen. Meaning, if I'm playing a baseball game and I press X to swing, it takes longer than it should for the batter to start his swing. It's not a terribly long at all lag but it is noticeable and does get annoying with timing games such as this.
  • Anonymous Jul 31, 2008
    yeah i have the same problem with an lcd tv and a plasma. it really is hard playing any online shooter is this just a problem for me or are all ps3s this way?
SOURCE: http://boardsus.playstation.com/playstation/board/message?board.id=confrontation&thread.id=735278&view=by_date_ascending&page=2
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source : http://answers.yahoo.com/question/index?qid=20081225141902AApX7cJ
Posted on Dec 29, 2008
  • Neubee Apr 06, 2011
    This worked perfectly for my new Sharp LC-52E810UN LED TV in Game Mode, no renaming to PC required. For Call of Duty (any), set "Look Sensitivity" lower than normal and it will be perfect!!!
Hdmi cable
Posted on Sep 25, 2008
No current cheap fix for lcd gaming lag yet, just play on your old tv. the only fixes will cost more than your lcd did
Posted on Jan 01, 2008
U can make it less delay till 4 or 2 MS but not 0 depinding on which tv u r using .. but there was some kinda tv (sharp) sold in japan with 0 delay for gamers
Posted on Aug 20, 2009
3 Suggested Answers
SOURCE: Lag between ps2, ps3 and LCD TV.
Reply for LAG!!!
You know alot of people dont know this but lcd tv's also have a speed and well the speed of your ps3 exceeds the response time the tv has. Which means some lcd's can be 1080p over 10,000:1 contrast ratio BUT can be slow.
Posted on Feb 18, 2008
this is not only the case with the ps2 and ps3 but also with xbox and xbox 360. I dont own a playstation but with the 360, I have tried all the different cables (composite, Component, VGA, and HDMI) and they all produce the same result. The issue is with the LCD TV. I have noticed that some games are worse than others. COD4 is hardley noticable, but halo 3 and GH3 are unplayable it is so bad.
Posted on Jun 11, 2009
Need to know how to hook up playstation wires are different colors
PlayStation usually has 3 wires 1 video 2 audio. on the tv yellow input its video. rotate the wires till you see it on the screen. then the other two are for audio. or if it's a ps3 purchase a hdmi cable.
Mar 14, 2013 | Vizio L32 32 in. LCD HDTV
Need to hook up my playstation 3 to my Sanyo tv
How are you connected to the set and from the playstation?
Jun 17, 2012 | Sanyo Televison & Video
Playstation 3 won't hook up to my dynex tv with
Did you check the side of the television for the AV/Compsite ports (Yellow, Red, White)? A lot of models have these connections on the side of the TV. You did not list your model number so I cannot really check for you.
May 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have recently linked my playstation 3 up to my new lcd 42 inch full hd tele. since doing this the movement on the screen and commands are slightly behind when i press the button on the pad. its like im...
Often times there is lag between game systems and HD t.v.'s, caused either by the use of HDMI cables and or audio/visual lag. The severity of this depends on the game.
If a game has audio/visual lag problems, there should be an option to compensate for it in the options menu. If it is a problem with usage of HDMI cables, try using different cables. If that doesn't make a difference, then you'll have to use regular old A/V cables.
Mar 10, 2011 | Sony Playstation 3 (PS3) Console
Lag between PS3 and LCD TV
How is your PS3 connected to the TV? only HDMI?
I can help troubleshoot but tough forum to do it.
generally, go over PS3 set up and select appropriate display. Video thought HDMI and sound though optical to receiver/amp should be your ideal configuration unless everything is all sony then you can see if pass thru works with your receiver, which is where I think you are have delays.
Tough though not much info.
Mar 28, 2010 | Video Game Consoles & Games
I hooked my playstaion 3 up to my new insignia 40inch. the blu-ray dvds work fine but when I play a game on it, the reaction time delayed by seconds...any suggestions??
Flat panel TV's do have a lag time involved in writing the information (picture) onto the panel. Some will have less lag time than others.
Dec 02, 2009 | Panasonic TC-32LX60 32 in. LCD Television
I recently purchased a plantronics 220 bluetooth to be use for socom confrontation. For some reason whenever the bluetooth is on I always get booted out of the game but when it is off, I can log in just...
just giv them back n the'll replace it...n they'll giv a new game with it too..
just ask them that wether it has a format of lcd tv or normal one!!...
Mar 04, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 on Sanyo Large Screen HD DT
It would be better if you went diretly threw a video source on the TV. Rn the wires from the PS3 to the tv and then select the source that it is connected to
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
2 questions:
Are you using HDMI cable?
Have you tried your ps3 in any other HDTV?
Heres why I ask you this. PS3 has some compatibility issues with some TVs (or Tvs have it with ps3....that is controversial xD) so if you happen to be so unlucky to have bought an HDTV which ps3 has issues with, you`ll have a problem (as was my case)
In my case whenever I switch resolutions or enter a game the HDTV starts flashing between the ps3 screen and some blank screen with dots. I have to remove the hdmi cable and connect it again and it solves. :D
So please answer my 2 questions in order to discard some possibilities.
Dec 21, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
14,740 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
