Question about KitchenAid KGRI801PBS Gas Kitchen Range
ERROR STUCK KEY F2EO - KitchenAid KGRI801PBS Gas Kitchen Range
    President:
  • 1,723 Answers
If you have tried to get the pad free from the fault code by messing with the buttons, it's probably going to have to be replaced. You nay trying to access the pad and pull the 'ribbon connector' and slide it back on, sometimes that brings them back to life. I looked up the part number for you and you can buy the new touch pad here and pop it in yourself:
Your touch pad:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-KGRI801PBS+-%3d%3dc281i1061056&PartID=1061056
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 24, 2009
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Posted on Sep 05, 2007
SOURCE: Error
f2eo stuck key sign
Posted on Dec 22, 2008
  • 24 Answers
SOURCE: I am getting an error
Error code f2e0 means the touchpad is bad. Give me the part number, or go to ApplianceTimers.com, we may be able to repair it.
Posted on Mar 21, 2011
I have a maytag wall oven it shows error code f2eo what does this mean and how do I fix it?
E0 F2 is usually a stuck key on the keypad. You will need to replace your keypad most likely. It's possible to be caused by the control board also. If it is NLA we can rebuild it for you at fixyourboard.com
Aug 13, 2015 | Maytag Ovens
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
I am getting an error code f2eo and it is saying stuck key. No button will work.
Mar 20, 2011 | Kitchen Ranges
Range showing error F2EO on Kichenaid Model KGRA806PSS00. How do we fix this.
The E0-F2 is an indication of a key pad being held down to long or a stuck/shorted key pad button. Most likely it has a shorted key; however there is small possibility of a control board failure too. This type of failure will require some testing in order to diagnose which component has failed. This normally should be performed by a technician.
Jan 20, 2011 | Kitchen Ranges
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Dec 13, 2008 | Kitchen Ranges
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Mar 20, 2008 | Kitchen Ranges
Oven not working
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KGRI801PBS Gas Kitchen Range Logo
268 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
