Question about Samsung TXE2549 25" TV
Line across the screen
Im getting sound and thonly picture i have is a line across the acreen
  • 4,234 Answers
This is a CRT based set and should have a small falt IC attached to a heat sink with the markings LA7837 or something similar. This is the vertical IC. Many times, the problem you are seeing is caused by poor solder connections at the pins of that IC. Try resoldering the pins first. If that failes to resolve the problem, replace the IC. The part will cost $10-$15 and should be available on the web. If you are not sure you have the corect IC, please post the marking on it and I'll confirm you have the correct one.
Thanks.
Dan
Posted on Sep 24, 2009
  • 189 Answers
HELLO
I have already answered some queries on this sort of problem. If the line is running horizontal, thin, bright and in the centre of the screen then you have field collapse. Cause is usually the field output IC failing or capacitors.
Either way, it looks as if it will have to be serviced! (:-).
Im getting lines across my screen alos flikering
Is it possible to see a picture of the fault?
Do the lines go away after a while?
Mar 09, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Plasma tv RT-42px10 vertical line appears on screen below cannot read subtittle. picture ok and sound normal. hoping that you can help me to solve this kind of trouble. i need your help thanks...
most of the time is plasma screen defective but if you want to replace the board where the the line is boards run to the bottom of the acreen su board or ss board if the line is on eaither side that side board to replace try and see if it makes difrence if not then screen is defective
Mar 06, 2012 | LG Televison & Video
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Line across middel of screen
Call 800-726-4405 for technical support and customer service - try to get your television replace
Mar 28, 2008 | Televison & Video
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Lines in picture
can you post a picture of the lines that are going across your screen? Sounds like maybe retrace lines.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Televison & Video Logo
85 people viewed this question
Henry  Thomas
Henry Thomas
