Question about Hoover Dryers
Loud screeching noise
I have the same problem, after turning the tumble dryer on you get a loud screeching noise. Anyone no this proble & if I could fix this myself.
Thanks
Rob
  • Hoover Master
  • 7,482 Answers
The problem is usually caused by dry drum roller.
You need to remove the drum and lube or replace the rollers
Posted on Sep 25, 2009
How to stop dryer from making loud noises and tumbler from hitting inside walls
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
Dec 04, 2015 | Dryers
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Loud noise when the dryer turns on
Well, sir, it is metal on metal, and you did well to stop it. Someone will be needing to take the whole thing apart and find the problem. It may be easy because the metal should show where it was rubbing because it will be shiny bright.
Be blessed.
Jan 08, 2014 | Samsung DV448AEE Electric Dryer
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Loud screeching noise at times when in use!
Normally loud screeching noises come from the drum rollers being dry.
They need lubricant, or replacement
Sep 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
My CDE6500 is making a loud tumbling noise while in cycle. It drys fine, but as loud as can be. Can anyone help me ?
There are a couple rollers that the drum turns on that have probably got bad bearings and need to be replaced.
Jul 08, 2009 | Crosley CDE6000 Electric Dryer
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Amana dryer loud noise
remove the lowe acesss panel( 2 5/16 screws) wiht the panel removed and a flashlight in hand, turn on the dryer and watch it tumble. you should be able to pinpoint where its coming from. its either the rear roller supports, the front drum glide assy's, or the tension pulley in ehich the belt its wrapped arund(develops a rut in which the belt has cut into it causing horrible screeeching noise, heck to replace all three of the components is problavle ony 50 bucks or so
Apr 23, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
342 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
