Question about Motorola Mobility RAZR V3
Stored backgrounds I have a razor v3 the darker silver version if it matters. The problem i'm having is I am unable to figure out how to delete images that I have saved from text messages that have been stored in the background folder. If I go to the background folder and highlight over the image I wish to delete the only option the phone is giving me is to either preview the image or plac it as my background. I just wish to delete it. ???? How?
Unable to charge
Um, you might need to either buy a new charger, or its your phone.
May 26, 2009 | Motorola Mobility RAZR V3
Recovering deleted msg from motorola razr v3
Does your V3 not have an Outbox function ?
Jan 22, 2009 | Cell Phones
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
FREE UP MEMORY ON A Razor V3
/a/
DL_DB_INET_RECORDS - Gets rid of provider shop links
Scarlet.tcf - Icon for scarlet skin (dont delete if you want to keep this skin)
Silver.tcf - Icon for silver skin (dont delete if you want to keep this skin)
ss_scarlet)176x220~~ - more theme/skin graphics
wp_scarlet_176x220~~
Silver Skin Wallpaper 176x2~~
Silver Screen Saver 176x2~~
mib_op_greet
OICQBuddyDatabase - Assuming this has to do with IM (dont delete if you are going to use IM)
**Pretty much everything else in this folder needs to stay the way it is, I may have forgot some files, but basically everything that has to do with the IM and skins can go!... make sure that you DO NOT delete the moto theme skin stuff!!!**
/a/mobile/audio
Delete everything except:
funlight.pat
MyToneDB.db
TempToneDB.bd
six .bas files
**Leave Start~up.mp3 & Power~down.mp3 if you want them... I deleted these files as I dont care for Startup/Shutdown sounds**
/a/mobile/pictures
Delete Everything
/a/mobile/skins/Scarlet (If you want max space and dont care about skins)
Delete everything
/a/mobile/skins/Silver (If you want max space and dont care about skins)
Delete everything
/a/mobile/system
shutter1.amr
shutter2.amr
shutter3.amr
shutter4.amr
shutter5.amr
wvim.emoticons - for IM
wvim_emoticons_yahoo
**do not delete mma_ucp/mma_dcp (menu) files or the count_down files (or your timer for your camera will not work anymore)**
/a/mobile/wvim
Delete everything if you dont care about your IM
also these folders
/a/mobile/mib, /a/mobile/kjava.
Also using P2kmenueditor I removed the IM graphic from the main menu and replaced it with the motomixer from the multimedia section because I had an extra icon after enabling the Video Camera. There are probably a couple other files I forgot about that I deleted but this is the bulk of it, pretty much leave everything in the /a/ folder alone unless I said delete, I didnt touch the following directories /a/mobile/audio/vavr, /a/mobile/certs.
The files names on your phone will vary from the ones I have listed above because most people dont have the flex my phone came with but you get the idea of what you can and cannot delete.
Jun 14, 2008 | Motorola Mobility RAZR V3
Razor V3
it would be best to call your carrier and ask them
Feb 06, 2008 | Motorola Mobility RAZR V3
Razor V3
You have to use the program "Moto Midman" or "Moto Midlets Manager" to upload a Java app to the phone. MPT wouldn't upload JAVA.
Feb 05, 2008 | Motorola Mobility RAZR V3
RAZOR 2 RINGTONES
Use Master Reset option Its get reset your phone
you also use Master clear option , all your phone data get erased
and also ring tone
Feb 02, 2008 | Motorola Mobility RAZR V3
Can't send text messages with pics
There is a program to unlock the Razor but is limit to some Razor model down load and try ......good luck and rate me..
RSD Lite Version 2.7.......its free serch and down load its comes with tutorial and is easy to use
Jan 22, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3 wont delete
Have you updated the firmware lately? Some of the newer versions wont let you delete your ringers once they are stored. Do you know how to use bitpim? If not shoot me an email and i can walk you through it. It is really easily to use. Good Luck!
Jan 03, 2008 | Motorola Mobility RAZR V3
Motorola V3 Razor screen and key pads don't work
i have that same problem, razrs suck, i hate em!! my screen is black, i can make and recieve calls...but my screen wont turn on, this is the 3rd time its happened...first time just restarted it...second time i let it sit without the battery in for over night...now it wont turn on no matter what...and the shiy silver circle peice on the left of the phone, the smooth one, it broke and fell off the phone, and i lost it at school...cingular is saying that voids the warrenty...
Oct 16, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
