Question about SanDisk Sansa e250 MP3 Player
Sandisk e250 volume will not go up fully, bar shows going up, but sound level does not. worked fine from new. thought might be a mute button, but cannot find one.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Suddenly lost sound
check the speaker, maybe its already open,
Aug 07, 2014 | Vizio Televison & Video
How to un-mute sandisk sansa mp3 player
The ring within the buttons is the volume controller move it clock or anti clockwise
Oct 18, 2013 | SanDisk Sansa e250 MP3 Player
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
I can't seem to get PowerPoint to pick up the sound from the microphone..... I have tried every conceivable setting under the sun.... Using Microsoft XP.... Message telling me to go to Multimedia...
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Mar 01, 2011 | Dynex Voice-Certified PC Desktop...
My microphone is built in to the computer but will not even show up in my recording devices. it used to work fine and now it doesnt say it even exists on the computer.
See last paragraph of instructions below re unlisted devices.
Click VOICE
That should be it.
Feb 19, 2011 | Compaq Audio Players & Recorders
How to unmute microphone (microsoft Vista)
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple smile.gif I hope I was able to help someone with this... wink.gif
Dec 26, 2010 | Computers & Internet
How do you adjust the volume on the Sansa e250 mp3 player
There is a volume button on your player. This is a link to your user's manual which will show you a picture of it:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk
I think the volume is supposed to be that way, its just one of the downsides to getting a sansa, and sometimes my sansa just goes really slowly, just push the botton once and wait, then if it still doesnt work push it again. i know, its not really a solution, but it might help.
Dec 07, 2007 | SanDisk Sansa e250 MP3 Player
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
