Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
Right door is lower than the left how do i level doors
    Top Expert:
  • KitchenAid Master
  • 12,744 Answers
If the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Posted on Sep 24, 2009
3 Suggested Answers
  • 35 Answers
SOURCE: Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Posted on Dec 09, 2007
  • 59 Answers
SOURCE: do i need special hinges to change this refrigerator from left hand door to right hand door?
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
How many airbag sensors in a 2008 gmc acadia
1) Front End Sensor - Right--Located under the front hood in the engine compartment (2) I/P Air Bag--Located at the top right under the instrument panel (3) Roof Rail Air Bag - Right--Located under the headliner, extending from the passenger front windshield pillar to the passenger rear windshield pillar (4) Side Impact Sensor (SIS) - RF--Located under the right front door trim near the lower rear of the door frame (5) Sensing and Diagnostic Module (SDM)--Located underneath the vehicle carpet under the center console (6) Seat Belt Pretensioner - RF--Located under the trim near the bottom of the center pillar (7) Side Impact Sensor (SIS) - RR--Located under the right rear door trim near the lower rear of the door frame (8) Roof Rail Module - Right--Located behind the garnish molding on the upper rear pillar (9) Roof Rail Module - Left--Located behind garnish molding on the upper rear pillar (10) Side Impact Sensor (SIS) - LR--Located under the left rear door trim near the lower rear of the door frame (11) Seat Belt Pretensioner - LF--Located under the trim near the bottom of the center pillar (12) Side Impact Sensor (SIS) - LF--Located under the left front door trim near the lower rear of the door frame (13) Roof Rail Air Bag - Left--Located under the headliner, extending from the driver front windshield pillar to the driver rear windshield pillar (14) Steering Wheel Air Bag--Located on the steering wheel (15) Vehicle Battery--Located at the front left of the engine compartment. (16) Front End Sensor - Left--Located under the front hood in the engine compartment
Aug 12, 2015 | GMC Cars & Trucks
I have a Maytag french door refrigerator Model is MFI2568AES Serial is 10039560JL. The refrigerator doors do not close properly because they are not aligned. The right side door has a bottom hinge...
Thank you for taking the time to explain this issue. I would need to see pictures of the part you have to compare to the diagram and determine your next move. I would with parts companies around the US and I can get you picture if you need them of how the unit was designed to work.
So either send me pictures of both door or I can send you snap shot of the parts list and pictures to assist you.
I have to ask, if the unit level and were the door removed at anytime prior to the current issue you have?
Thanks
Oct 15, 2013 | Refrigerators
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
GE side by side doors are not alligned
here is a diagram of the doors and the hinge area. Without seeing myself I can only gusess.
you box could be twiked or not level. The hinge at the bottom could be bent. There top hinge sometimes can have an ajustment that moves the top of the door left and right wich will raise the door a littel. to see if this has an ajustment you will need to remove the top cover of the top hinge and loosen the bolts a little and move the door left and right, if it does have someone hold the door where you want and tighten.
Jan 11, 2010 | GE GSS22SGM Side by Side Refrigerator
GE Side by Side Frig Door Flies Open to Far
Look under the front of the fridge, should be some adjustments to raise and lower the wheels or feet for leveling. Level it with a level on the top, should help keep the doors from swinging.
Sep 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
Cant open the door
Under the unit you can access the leveling mechanism for the legs. Try adjusting the levelers so the unit is lowered. Do so a little at a time and try to keep the unit leveled from left to right as you lower it. This may take tension off of the latch and help you get the door open.
Jan 27, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
434 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
