Question about RCA HD52W59 HDTV Projection Television
I received an RCA CTC 195 Home Theater Television from a neighbor and the picture is distorted all 3 primary colors Red,Green, and Blue seem to be off center almost 3-d ish...is there a solution to this?
  • 2 more comments
  • kris_garland Sep 24, 2009
    I am comfortable with soldering and have worked with voltage before so those shouldn't be factors for me...thank you for the help.
    I dont know if my last comment was posted right so I am posting again lol...Dan I have worked with both soldering and voltage before so neither should be a problem for me...I am interested in fixing this convergence problem myself and really appreciate your help.
  • robert landry Dec 24, 2013
    yep , it a convergence problem, you have a seperate board on the middle, in the back so called power supply, it's has multiple output voltage, one of witch is 130 volt dc.. check it out, if the 130 volt is missing it's your problem.... to fix it, on the same board it has a mos fet ( driver) AND 2 CAPS... REPLACE THEM.D(in This sets were badleyRCAinfo rlandry@vianet.ca
  • RCA Master
  • 8,457 Answers
Here the website to buy a convergence kit.Tv repair World.com.Use all parts what in that kit ur convergence will be back to normal,so ur tv.
Posted on Oct 23, 2009
    Novelist:
    Scholar:
  • 95 Answers
HI the reson it is convergience problem, bad power supply. The board is about 10" x 4", the power supply may be burt or deffective issues. I can send you a copy of the schematic , or I can help you to trouble shoot it. First find J19700, this should have input voltage of 120v.
The output voltage connector # J19701 , measure the voltage from ground pin #3 with 1 should be -45, with #2 is -15, #4 is 25, #5 is 15 and pin 6 is 45. If it mesure 0 , check for broken solder or band main IC U19700. If the voltage is low, it is a bad cap or diode, seen this very common, Goood luck, rlandry@vianet.ca
Bob the Builder.
  • 4,234 Answers
This is a convergence problem that is relatively common. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages, you can probably fix this yourself. Please let me know if you wish to attempt the repair. If not, the parts cost for this repair should fall around $50.
Dan
Posted on Sep 24, 2009
  • 832 Answers
Yes, your RCA CTC 195 HT TV needs repairworks by
TV technician. That is the only solution.
A red blue and green line jus appeared across the screen of my 55 inch rca floor model big screen. instantly my picture and color become distorted
conversions are out....rca ... check for bad connections on circuit board around fryback xformer. check fuse by flyback xformer...fuse is shaped like a little plastic rectangle>>fuses should measure a SHORT when GOOD! Flyback Transformer is large in size and sends highvoltage to 3 picture tubes via a SPLITTER . easy to locate
May 19, 2010 | RCA R52WH73 Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" Model D52W23 Color Distorted
its not due to the fuse.its the problem of the ic on the maIN BOARD of the tv just check out for the faulty on the main board with multi meter and replace it.
Dec 19, 2008 | Sony KP-51WS520 51" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA BIG SCREEN TV - COLOR PROBLEM
If your TV is rear-projection system, it got problem in convergence board, may be few bad-solder connections.
May 30, 2008 | Audio Players & Recorders
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Color red,green and blue is making a circle on the screen
Hello, please replace the PTC resistor. It is positioned at the primary side of mains converter. Best regards, Arpi
Aug 23, 2007 | Zenith B27A11Z 27" TV
RCA HD52W59 HDTV Projection Television Logo
317 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
