Question about InFocus ScreenPlay 61" Rear Projection HDTV
TV screen flashing on and off
When I am watching my TV, the screen will turn on for 30 seconds, then off for 1 minute. When the screen is off, all the blue lights flash a few times. The sound is on the whole time.
  • 2 more comments
  • Anonymous Jun 18, 2008
    TV screen flashing on and off problem
  • tamaralee1 Aug 22, 2008
    I think my fan has gone out in the back of my 61". Now the TV will turn on but shut offs soon after and the blue lights flash on the bottom left panel. Sometimes the TV will stay on, but I have put a fan where the heat is coming out of the back of the TV which seems to keep it cool. I watched the Olympics last night. Came home from work today and now my TV will not turn on. The surround sound works, however no picture, just flashing blue lights in the panel.
  • BuLLitz Nov 08, 2008
    Mine is doing the same. I thought that perhaps it is a problem with overheating but do not know. It's too big to take to a repair shop and probably not worth having someone come in and repair...
  • Anonymous May 25, 2009
    my screen flashes down to the center of the screen ,and only shows a white line across the center of the sreen from left to right.
This is what I found on mine. There are three wires powering the fan. They routed beside and under the fan. They are separated from the cooling fins by a bakelite(?) material. There is a shrink sleeve around them. I noticed the shrink sleeve was brittle so I cracked it with a pair of pliers. When I did I found the insulation was off of the wires and they were together. I cut the wire and re-routed them around the two prongs that hold them against and under the fan. The fan worked and my problem was solved.
I contacted Infocus and they acted as though I were talking Greek to a Geek. Hope this Helps.
Posted on Jan 20, 2009
    Genius:
  • 2,920 Answers
Burnt out fan or your power supply went out
Posted on Nov 03, 2008
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Video Disappears Intermittantly
The TV power supply may be failing.
Oct 19, 2017 | Vizio VP322 32 in. Plasma TV
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 08, 2012 | 2000 GMC Yukon Denali
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
After 1 minute delay, turns on screen covered with colored spe
I just turn off the TV set, wait 30 seconds, then tun it on again and the
specks are gone/
Dec 13, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Flashing Off
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
Feb 08, 2018 | Samsung SyncMaster 2253BW LCD Monitor
Put new ignition in 2003 sunfire. engine wont stay running and theft lock symbol on in dash
HI.
Follow this step to keep running your sunfire.
1 - Be sure the battery is full charged.
2 - Is better if you put a battery charged
3 - Turn the key to run position and tray to start the car and leave with the key in run position,
With a watch let pass 10 minutes no less. you gonna see the security light flashing and stop flashing after 10 munites.
4 - After 10 munites turn the key to off position during 30 seconds, with watch on your hand, OK.
6-- After the 30 seconds try to star the car
I hope this solve your problem.
Please letme know.
Thank you for use fixya.
Jul 11, 2008 | 2003 Pontiac Sunfire
Lamp replace twice.
Light engine replacement is next.Contact Mits tech in your area.
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
InFocus ScreenPlay 61" Rear Projection HDTV Logo
759 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
