Kenmore Front Load Washer Model #110.82980810 Will Not Drain
I've had this washer about two years. I've experienced my first problem with it today. I went to put the clothes in the dryer and noticed the clothes were still very wet. I noticed the knob was not on OFF. I turned the knob back to heavy load and it filled back up with water and it started to spin again. I thought everything was ok, but it stopped in the same place again. It clicked twice like it was going to start to drain, but it didn't. So basically the problem is that it will not drain. Does anyone know what I should do? Would it be cheaper to buy another washer? I think I bought it for less than $200. Thank you in advance.
jsrock516
  • 5911 Answers
SOURCE: kenmore elite front load washer - wont drain and loud clicking sound from bottom
Yes...sounds like you may have something lodged in the drain pump impeller. The following link explains how to check the drain pump on this washer for obstructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
It does not take much to damage the drain pump on this washer. If something has been lodged in the pump for any significant period of time, the pump may be damaged and required replacement. The may still run, but may not be pumping water as it should. You may experience an error code as well. On HE3 models, the error code is "F02" or "SUD". On HE5 models, I believe it is an "F21" error. Replacement pumps can be ordered on line at searspartsdirect.com.
If you find that you need to replace your pump, I have this additonal link, that provides step-by-step instructions:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Please read the note at the bottom of the link, as it IS possible for a pump to still run and not pump water. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 16, 2008
  • 958 Answers
SOURCE: Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
DRACO A5OG
  • 22 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Posted on Dec 31, 2008
  • 106 Answers
SOURCE: Kenmore front load won't drain spins then blinks no spin
Yes this is the place, but you have to mop up the water or it would flood the place; clean out the muck from the filter and refit carefully. You have to clean your filter according to usage, the filter does not self clean, no way.
Posted on Mar 01, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Error code f 02
I think it's a slow drain fault. But would need full model number to say for sure. Still it wouldn't hurt to check the drain pump for crud. Here are some vids that might help. Don't worry too much about brand specifics. Many brands share identical and similar parts.
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Kenmore model 970c44102 front load will not drain while spinning
sound's like the water pump is going out I got a old washer and it dose the same
Sep 15, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load he3 kenmore, control panel had an F now is locked up! Have unplugged for 30 min. no change
I just experienced a similar problem, getting an F21 error and 5d.
F21 error was a clogged drain. Unplug firest, then remove the lower front panel (it may be from the back panel) and look for a drain valve. unscrew and clean out good. I found approx $6 in change, keys, bobby pins, hair clips, etc. then put all back together and run a cycle empty. Save myself $250 I dont have and did it myself. This website is wonderful.
Denise
Dec 17, 2010 | Kenmore Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer won't drain
your water pump has something in it which keeps your pump from turning to push out the water.
May 06, 2009 | Kenmore 43142 Front Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
