Question about Mercury Electronics CyberPix S-555V Digital Camera
How do i turn on my flash it used to now i
How do i turn on my flash it used to now i cannot turn on the flash
Won't turn on
Ric DonatoSorry to hear that with fresh batteries it will not turn on. If it used to turn on, then now there is something wrong with the flash. Other than using different batteries, making sure they are in the correct order, and still it does not flash it will need to go to Nikon repair. Yes, I would not want to hear that answer, but that may be the only solution.
Nov 28, 2013 | Nikon Speedlight SB-600 TTL Flash
My camera say no flash because of micro mode how do i turn the flash on?
The Micro mode is used to shoot close up images. Turning on the flash in micro mode will result washed out over exposed images. Hence in most cameras, choosing the micro mode will automatically disable the built in flash. Some Camera will show the message, cannot use flash or flash cannot be changed because of the micro restriction. This is normal operation. If you wish to use flash, please use some other manual priority mode.
thanks for understanding.
Feb 18, 2011 | Vivitar ViviCam 8025 Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
How do you turn the flash on
Using the Flash
The flash is designed to function automatically when lighting conditions permit the use of flash.
The camera has 3 flash modes: Off, Auto , and Always On. You can take an image using
a desired flash mode to suit your circumstances. The flash's effective range is
35.4” ~ 59.1”(0.9m~1.5m) (in Normal mode).
The flash is disabled if the camera is set to Macro mode.
1. Press the Power button to turn the camera on.
2. Toggle until your desired flash mode appears on the LCD display.
3. Compose your scene and press the SHUTTER button
to capture your image.
Flash button is the one like an arrow pointing downwards. (not a straight arrow) Usually located beside Disp, OK, Menu.
Apr 03, 2010 | Polaroid A500 Digital Camera
How do I turn the flash on on my Nikon D70?
if u select mannual mode u have to press flash button,whitch is on left side below flash unit,if u select auto mode, flash itself elect when u half press the click button.
Mar 08, 2010 | Nikon D70s Digital Camera
How do i turn on the flash on the sony cyber-shot dsc t77
1. Touch the Flash (Auto) icon.
2. Select the desire option.
a. Flash Auto - auto flash when needed.
b. Flash ON - Flash always ON.
You can also refer the page # 12 and 23 of 108 in Instruction Manual of the Camera for detail information to turn on the Flash.
To download Instruction Manual check the link given below:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT77
NOTE: You can not use the Flash when the Camera is set to Burst or Multi Burst mode. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection. You can not use the Flash when mode dial is set to Movie also.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
When I try and turn on my phone it flashes and doesn't turn on just keeps flashing on and off.
Jul 01, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My nokia 6600 won't turn on
flash you're phonewith another version..complete the flash and make sure no step is missed.. what software are you using?..use an older box to flash your phone,better to use tornado gdfs3..it gets those nokia types up and running..
Jan 10, 2008 | Nokia 6600
Mercury Electronics CyberPix S-555V Digital Camera Logo
18 people viewed this question
Top Mercury Electronics Cameras Experts
Steve
Are you a Mercury Electronics Camera Expert? Answer questions, earn points and help others
