Question about Kenmore 73952 Gas Dryer
I have a Kenmore series 90 gas dryer that has been converted to propane, model 110.74912200. the burner will light and stay hot for about 3 minutes and then will cycle off and only blow cool air. I have cleaned the vent tube, cleaned the vent itself, replaced the thermal fuse and the cycling thermostat, no change, will start hot then blow cool air. Any help I would sure appreciate it, thank you.
  • Anonymous Mar 18, 2014
    vent cleaned ,
    President:
  • 1,776 Answers
I would suspect faulty gas valve solenoids. These electrical coils are right above the gas valves and when energized, these solenoids open the valves to permit gas flow. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. They will most likely come as a set from the parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 24, 2009
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
Kenmore gas stove can it be changed to work for propane
Yes, your gas range can be converted to propane. Your owners manual will give you step by step instructions. Since there are many different models, there are different procedures involved to convert to propane. On some models you must change the top burner orifices where other models have adjustable orifices. The oven burner has an adjustable orifice(same with broil burner if there is one). The range regulator must be adjusted to stay open all the time because your propane system has its own regulator.
Mar 21, 2010 | Kenmore Kitchen Ranges
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
No heat
If the burner assembly is not lighting I would recommend you look into an igniter replacement. If the igniter is worn, or does not work at all, the gas safety valve will not open and you'll never get ignition. The part number is 279311.
If the burner assembly lights, then goes out after a few minutes, I would recommend you replace the gas valve solenoids. There are two of them on the burner assembly. It is recommended that you replace BOTH of them at the same time. The part numbers are 69540 and 69539. Searspartsdirect.com has an excellent illustration of your dryer. Just type in your model number and look under the "Burner Assembly" heading. The igniter is listed as item 4. The solenoids are items 13 and 14.
If you have questions, please let me know. I hope this is helpful to you.
Mar 03, 2009 | Kenmore Dryers
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 73952 Gas Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
