Question about Intel Desktop Board D845WN Motherboard
How to connect power supply to intel desktop board of d845wn
  • fixit0909090
    fixit0909090 May 11, 2010
    is it a 24pin or 22 pin power supply
  • 39 Answers
Hello Ahmed, All Cpu comes with power supply in a form of a metal box about 4" x 4" x 3" with alot of wires in a bunch or in pairs. Plug in the black/white cable at the back of the Cpu socket and then to the house supply and switch on. Thats it!
Sirjohn
Posted on Oct 29, 2009
  • 23 Answers
Hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Posted on Sep 25, 2009
Intel desktop board d845wn front panel powder led, power switch, hdd led, reset switch connection problem.
Hi, here you can read info and download drivers
for your mainboard:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845wn
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
Sep 20, 2011 | Intel Desktop Board D845WN Motherboard
I haven't driver
here : http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845WN
Mar 05, 2011 | Intel Desktop Board D845WN Motherboard
After installing my Intel D845WN m/board and connecting up the power supply with the ram, AGP card etc., the processor fan on top of the heat sink started running when I switched on the main power supply...
You probably have the case panel connections in the wrong places. Double check the board's manual and the connectors. Most case manufacturers have the connectors printed with their functions.
Oct 14, 2009 | Intel Desktop Board D845WN Motherboard
133hz sdram problem
Please check this Intel link that shows specifications for memory that can be used in the Intel D845WN motherboard.
http://www.intel.com/support/motherboards/desktop/d845wn/sb/cs-008941.htm#1
When upgrading or increasing memory. The DIMM's should be the same. The Intel D845WN board requires the memory to run at 3.3volt. If the memory you are adding is within the Intel spec's, than switch the two Dimm's. Insert only the new DIMM & check if the system hangs. If it does than it is possible the new memory it either not compatable or is defective. For more information about the D845WN board download the manual for you're Intel board. http://support.intel.com/support/motherboards/desktop/d845wn/sb/cs-008937.htm
Luck!
Mike
May 19, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Motherboard
do u have pw switch on right pins power p start with red on that oen go over one to conect the black try both ways never up down on pins tho side to side only ok
Jan 25, 2008 | Intel Desktop Board D845WN Motherboard
Intel Mother Board D845WN
Seems there is a loose wire, loose card, motherboard failure or mis-plugged wire. IS everything in right?
Nov 09, 2007 | Intel Desktop Board D845WN Motherboard
Intel Desktop Board D845WN Motherboard Logo
197 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
