Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
How to Refill HP940XL Ink Cartridge? - HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
I just bought a printer that uses these same cartridges & I just got off the phone with Cartridge World. Apparently, the cartridges can be refilled, but there's a microchip that prevents the refilled cartridge from being read as "full" by the printer. They are working on "cracking the code" and, once they do, refilled cartridges will be available from them. I don't know if or how that microchip can be replaced if you refill your cartridges yourself, sorry.
Posted on Oct 14, 2009
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Can you refill dell series 21 ink cartridges?
Any ink or toner cartridge is refillable, For ink cartridge, check for the small pin hole at the top of the cartridge to inject the ink refill. But remember that the ink should be compatible with your ink cartridge model. Good luck
Jan 05, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
I refill the ink cartridge colored and its says check ink u051 colored
it is not advisable to refill ink cartridge. it will only damaged you cartridge. but if you are trying to save money then refill ink cartridge ONCE only.
Feb 25, 2010 | Canon PIXMA MX310 All-In-One Printer
Lexmark 2300 series
yes you can refill the cartridge.
Each kit includes 3 bottles of photo ink (1 bottle each of photo black-photo cyan-photo magenta) plus all refill-tools and instructions needed to successfully refill your Lexmark 18C0031 cartridge.
The trick to extending it's life is to know how to add Ink, and to only use Ink which matches the ink which originally came with your cartridge. Each cartridge is manufactured to work with a specific type of Ink, and will not work correctly with anything different.
Apr 10, 2009 | Office Equipment & Supplies
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Refilling of canon ink fine cartridge pg 41
you must buy a brand new cartridge do not refill your old cartridge and use it again it may cause malfunction of your printer..one thing you have encounter is " the cartridge is not recognized"
Feb 15, 2009 | HP Office Equipment & Supplies
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
1,572 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
