Question about Irons
Heat press does not heat up
Changed the fuse and the heat element still i get no heat please help could it be the coil ? if it is where can i get one.
Steamglide 2200 not heating up fuse ok
The internal element may have shorted out and thus the sole plate with heating elements will not operate any longer. The cost of repair exceeds the cost of replacement.
Dec 09, 2014 | Irons
There is no heat from the iron. Happened all of a sudden
Guess the heating element has burnt out. Or open it up and checck if the power is being delivered to the element. If being delivered then then the coil has burnt out.
Apr 20, 2011 | Tefal UltraGlide 1749 Iron
My iron stooped working all of sudden.I was pressing cotton clothes, all of sudden it stopped heating. No light in it.
If the input led is not glowing it means the connection to the mains inside your iron has got disconnected. Just open the iron. Check the input on the mains and check all the three wires are connected properly. It will heat again. When you were changing to cotton. You asked more voltage to the heating element and possibly due to more voltage the connection got broke and now the circuit is incomplete hence no led and no heatup.
Apr 25, 2010 | Irons
I have a DX 6700 that does not come on when plugged into the outlet.
Hi.
Either the wiring to AC power line is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
If the power cord is fused (like for example in UK), check also the fuse in the power cord, try replacing it.
Regards.
Jan 17, 2010 | Rowenta DX6700 Iron
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
My yamata fp202L
Most likely it is the fuse that regulates the heating element on your press that has burned out.
All you have to do is open the top, remove the heating plate. The fuse will be on the left, button shaped.
Replace the fuse and put everything back together and the unit should work.
You can buy a fuse from the company you bought your press at or contact the manufacturer.
Sep 10, 2008 | Yamata FP202L Cordless Iron with Auto...
Won't heat up
What sounds like is the fuse that governs the heating of the unit is either burned or not functioning. You can get a manual on how to fix that directly from feiyue yamata's site here. http://www.feiyueusa.com/Manual/FP202ELFuseChange.pdf
The problem is that if you have a psp990, it is not their item, it is a rebranded yamata so they dont have specific instructions for it. After you changed that fuse, i am almost positive you will be able to use your press again.
Jan 05, 2008 | Yamata PSP-990A Iron
Irons Logo
176 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
