Question about Motorola Mobility H710 Bluetooth Headset
Motorola H 710 mic does not work
I have a H710, the voice dialing works great, I can hear an incoming call great everything about this unit works fine except that the party I'm calling or who are calling me can't hear me when I speak. The unit hasn't been used that much but a new law is coming in effect next year making it illegal to use your phone in the car so a bluetooth is the only answer. I have tried other makes but like this unit the best. Hope someone has a solution other than purchasing a new one.
Thanks
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone.
Please contact us.
Mark
Motorola Support
CONTACT US
Jun 04, 2014 | Motorola Mobility H710 Bluetooth Headset
Lost outgoing voice signal. Can dial out, recieve calls & hear
Your problem is with the mic, probably it's not working anymore or maybe it's been displaced or wiring problem. It's better for you to get it repaired from a mobile repairing shop. You might make mistakes if you don't have enough idea with it. They'll replace the mic and the problem will be fixed. Good luck Thank you for using FixYa.
Jun 01, 2010 | Nokia 6131 Cellular Phone
Why does my headset not seem to register my voice
The microphones on the h710 seem to be very susseptable to moisture. My first one failed to work after soaking in coffee,,,oops! My seocnd one worked great until I was out working in a field and had it in my shirt pocket. My shirt was damp with sweat. Never worked right again. same issue, I can hear just fine with it but person at the other end say they can hardly hear me. too bad, I lobe it, but they are unreliable
Apr 07, 2010 | Motorola Mobility H710 Bluetooth Headset
Motorola mic no longer works. Any fixes?
This is probably a broken wire inside. the microphone piece moves back and forth to turn this unit off and on and the wires have broken because of it. there is a similiar problem with the H800 as the mic extends in and out to turn it on and off.
Nov 07, 2009 | Motorola Mobility H710 Bluetooth Headset
Bluetooth H710 new..mic not working
Go in phone to setting then go to bluetooth and press it then select voice routing incoming hands-free
Aug 25, 2009 | Motorola Mobility H710 Bluetooth Headset
Motorola H710 mic not working
i pinched the flats sides of the boom together tightly and used my ps3 to measure the clarity and went from mic not working to semi to full clarity
Jul 02, 2009 | Motorola Mobility H710 Bluetooth Headset
Motorola Mobility H710 Bluetooth Headset Logo
280 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
