Question about HP PSC 1315 All-In-One InkJet Printer
Cartriged keeps moving back and forth ready for printing but no paper is loaded. The feeder makes a noise but nothing happens.
  • 30 Answers
Try cleaning the rollers
Posted on Sep 24, 2009
My AR-168D is having doc feeder problems.If paper is loaded intpo the document feeder the light comes on that recognizes the paper is loaded.When i press copy nothing happens but the scanner moving over to...
Thats pretty easy to fix. Remove the glass. You lift the document feeder out and remove the 2 screws from the front and back of the glass.
Once the glass is removed, Take some rubbing alcohol, or good cleaner. Formula 409 , fantastic etc, dampen a cloth towell and clean the stainless steel shaft on the rear of the scanner that the lamp rides from left to right on.
I bet if you try and move the scann lamp carriage it is very hard to move.
Clean it a couple of times. Get e very light weight oil and put a light ammount on that shaft. Run the carriage back and forth a few times, clean and relubricate the shaft and you should resolve the problem.
Very common. I would say there is a 99 percent likelyhood that this will fix your problem.
Aug 09, 2010 | Sharp AR-168D Copier
My lexmark all in one printer x5470 keeps jamming the paper and it wont print?or the paper will go in partially and print but nothing will happen then it will tell me to reload the paper and press the...
Most probably a mechanism problem. Try to remove all sheets of paper. Take out the cartridges from the printer. Close the cover. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Check for any obstructions or foreign objects in the feeder. Wait at least 30 seconds before plugging the power supply back in the printer. Once printer is ready, reload the cartridges. Load about 10-15 sheets, don't load too much. Let it print the alignment page. If this doesn't help, then most probably it's a hardware issue. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
Jun 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
Epson stylus C43UX. my printer keeps saying paper jam and paper not loaded correctly and just spills out the paper i load. the paper is loaded perfectly but it just wont print! the stupid red light just...
The printer reports a paper jam because the paper feed system cannot feed paper.
Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. This is presumably not happening! Can you what does happen?
If the expected movements are not happening, you need to remove the printer top cover to see what the problem is and resolve it - perhaps the ASF has come loose or something. This is easy if you know how to do it - otherwise it's likely to cause you to take a large hammer to the task! If you need help on this, please report back with a new post.
Mar 27, 2009 | Epson Stylus C43UX InkJet Printer
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Printer won't print
  1. first you make a self test print by the printer, for this you first switch off the printer then press and hold the button on your printer, and switch on the printer
  2. if you get the test printout all the characters on paper
  3. now you can find the printer is ok and it is work in good condition
  4. now check the cable connection, if it okay
  5. check the installed printer driver software
  6. for these purpose
  7. re install the printer software
  • If your computer not self printing do as follows
  • now your printer is in trouble
  • clean nozzle, print head, align catridge
  • for these go to printers and faxes, on start menu, click right mouse button on the printer icon, select printing preferences, select maintenance option
wish you all the best
Jan 29, 2008 | HP Deskjet 3845 InkJet Printer
HP4 and PC LOAD LETTER MSG (and there is paper)
Hi, I assume you can run paper thru the manual feed without any problems? If so the paper sensor that detects the paper in the tray has either broken or fallen off! If you take the paper tray out and tilt the printer a little bit on it's back you should see a sensor that will swing back and forth its' solid black/plastic . The sensor is very cheap and I'm pretty sure this is the problem> Good Luck!!
Nov 29, 2007 | HP : HP4 Laserjet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
