Question about Texas Instruments TI-84 Plus Calculator
The Y= screen has an arrow to the left of the Y1 that I have never seen and wont let me graph more than one equation at a time, also the calculator graphs asymptotes, how do I get it back to the factory settings?
Thanks flutedude! That was driving me nuts.
It was the Transfrm app (at least it was for mine). Select it from your APPS list and then Uninstall.
Posted on Mar 24, 2010
    Problem Solver:
  • 10 Answers
One of your apps is on that shouldn't be on...
I think that it's in the bottom portion of the alphabet, I don't remeber
just turn off your app and you should be fine
Posted on Sep 24, 2009
Cannot graph two equations together, & trig graphs are not correct.
At first in Y editor type Y1=2*cosx and for example y2=[5*exp(-x)]-5 and then graphing it. Set RAD mode of course. See captured images
Jul 10, 2012 | Texas Instruments TI-84 Plus Silver...
There is a variety of solid arrows in front of the Y1= in the screen to enter equations to be graphed. How do I get back to the original \?
Repeatedly press left-arrow to get the cursor over the arrow, then press ENTER to cycle through the different graph styles until you get the one you want.
Jun 17, 2011 | Texas Instruments TI-84 Plus Calculator
I have a student in my Precalculus class who is trying to graph several equations simultaneously, and her calculator will only display the graph of one equation at a time. In the equation editor, the...
Some time or other she played with the Transfrm Application. It remains in memory and takes over the graphing capabilities of the native OS. It must be kicked out of memory.
  1. Press [APPS]
  2. Use Up or Down arrows (Up is faster) to get to the bottom of the APPS list.
  3. Locate [:Transfrm], highlight it and press [ENTER]
  4. In subsequent screen, select the [UNINSTALL] option.
  5. Go back to the [Y=] screen and enter or edit your functions.
  6. Press [GRAPH] when finished entering the functions.
Oct 07, 2010 | Texas Instruments TI-84 Plus Calculator
Hi, I'm really confused,,,i tried to use the LIMIT equation on my calculator but i couldn't,, so, need some help.. 2- the other thing is i want to know how to use the graph and i want to check my...
I am not aware that the Casio FX-9750GPlus has a LIMIT application. If it does I would like to know how to find it.
As to graphing, read what follows. Window questions is at the end.
I will show you how to draw a simple function such as y=5*X 2. The method is the same reagrdless of the complexity of the function.
  1. Turn calculator ON. If you do not see several icons press [MENU].
  2. Use arrow to select the [GRAPH] application and press [EXE].
  3. In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
  4. Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
  5. At the position of the cursor type 5 then press the [X, theta,T] key, under the [ALPHA]. On the screen appears 5X, complete your equation by typing [ ] 2
  6. Press [EXE] to store function.
  7. If you want to draw other functions, it is time to do so on that screen.
  8. When done, press [F6:Draw].
  9. If the screen does not show a lot of the function, you can use the arrow keys to pan (move the center of the graph. You can pan Up, Down, Left, or Right.
  10. You can also press [SHIFT][V-Window] to set the window limits.
  11. You can also press [SHIFT][ZOOM] and select [F5:AUTO
Sep 24, 2010 | Casio FX-9750GPlus Calculator
How do you graph an equation on the calculator? For example, my equation is y=-1.5x 2.
All right, I will show you how to draw a simple function such as y=5*X 2. The method is the same reagrdless of the complexity of the function.
Sep 15, 2010 | Casio CFX-9850G Plus Calculator
How do I use the graphing part of my casio fx-9750G
All right, I will show you how to draw a simple function such as y=5*X+2. The method is the same reagrdless of the complexity of the function.
  5. At the position of the cursor type 5 then press the [X, theta,T] key, under the [ALPHA]. On the screen appears 5X, complete your equation by typing [+] 2
Feb 14, 2010 | Casio FX-9750GPlus Calculator
How do u store linreg(ax+b)as y1 on ur graphic calculater
When you press [STAT] and right Arrow to highlight CALC you see two linear regression model [4:LinReg(ax+b)] and [8:LinReg(a +bx)]
If you select [4: ...] the command echoes on main calculator screen as LinReg(ax+b) and a blinking cursor
If you press [ENTER] you will get your equation, a, b, and r^2 if DiagnosticsOn command has been executed before. However you will not be able to see the line of best fit on top of the raw data scatter plot.
To save the equation of best fit in a function variable, ex Y1, you complete the command as follows
LinReg(ax+b) [VARS][=>][Y-VARS][1:Function][1:Y1]
The Y1 variable will appear on main calculator screen, and you have
LinReg(ax+b) Y1
Press [ENTER]
Screen display the equation, its parameter and its correlation coefficients (if so configured).
Press [GRAPH] to draw the line of best fit on top of the scatter plot.
Here are two screen captures to show you the equation and the line of best fit.
As you can see from the value of r^2, and the graph, a linear regression does not seem good.
Feb 01, 2010 | Texas Instruments TI-84 Plus Calculator
How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
Hope it helps.
Oct 10, 2009 | Casio FX-9750GPlus Calculator
I can't graph more than one equation in the y= area of my Ti 84+
The marking that so puzzle you define the type of line (or dots) to represent the graphs. Enter as many functions as there are Y variables.
After entering a function press [ENTER] to jump to the next one.
When finished entering all functions press GRAPH. If you want graphs drawn one after the other, in MODE highlight Sequential (6th line) and press ENTER. If you want graphs drawn simultaneously, in MODE (6th line) highlight Simul and press ENTER. Press 2ND QUIT to return to previous screen . Execute graph again.
Hope itr helps.
Sep 23, 2009 | Texas Instruments TI-83 Plus Silver...
Graphing multiply equations
When you go to Y=, you should get a list that says:
Y1=
Y2=
Y3=
etc. You just enter the first equation into the Y1= space then hit ENTER and it will go to Y2=. Enter the second equation there. After you have entered all of your equations, push GRAPH and they should come up in order but they will all appear.
Also, make sure your window is set appropriately so that you are able to see all of the graphs.
Lastly, when you look at your Y= screen, are there funny looking arrows before the Y=? If so, do this:
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
  • Hope one of these are helpful!!
    -Gretchen
    Feb 18, 2008 | Texas Instruments TI-84 Plus Calculator
    Texas Instruments TI-84 Plus Calculator Logo
    137 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
