Question about RCA D52W19 52" Rear Projection Television
TV will not turn on.
When power button is turned on green light will flash on and off 3 times over a 20 sec. period. We have to wait 1 full minute after 3rd flash and hit power button again to get the same thing: blinking on and off 3 times in 20 sec. period and not coming on. After repeating this several times TV would eventually come on. Everyday we kept repeating this procedure over & over and It was taking longer and longer to come on. Eventually it was taking an hour, and then finally it would not come on at all. A TV repairman told me he did not have to come out and charge me $70.00 to tell me it is the "power board". It was going to cost me about $550.00 to repair it. My neice's TV was doing the same thing and she said she had to put a heater on hers to warm it up before she could get it on and now hers will not come on at all. Our 52" RCA TV is only 3 1/2 years old.
  • 979 Answers
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Posted on Dec 24, 2007
Sony Bravia KDL-55EX500 flashing green and yellow light, an won't turn on. Any suggestions?
you guys are going to love me. lol. i figured it out at least for mine. $ )
1.start by unplugging the tv and everything plugged into it(make sure the only thing plugged into the tv is the power cord).
2. next plug in the usb flash drive with the update or a compatible version of the firmware.
3. now while holding down the up arrow button on the tv remote, plug in the tv and keep holding the up arrow while pressing and holding the power button on the side on the tv until you see the light on the tv go from solid green to solid red and yellow flashing lights. once you see this just sit back and wait a few min for it to force the update and it should turn on when its done.
let me know if this works for you as well or if you need any clarification. also know that step three is a pain to do alone and must be all done within a short period of time preferably at the same time.
I’m happy to help further over the phone at https://www.6ya.com/expert/ian_82ea3666497c1024
Oct 16, 2011 | Sony Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Wast Ink absorber is full. Any solutions?
Try :
These are the steps:
1. Turn On iP1600
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
Or
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 25, 2010 | Canon PIXMA iP1600 Printer
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
All lights are flashing
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All the best Pineworks
May 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Pixma mp150 E5 flashing and b + c flashing and warning light on! have recently put in cartridge world inks but have already printed with them now its playing up each time you try to use printer.
Canon printers MP 160 AND MAYBE OTHERS
it.
procedure:
button pressing
the "service mode"
Try it
it.
Mar 17, 2010 | Office Equipment & Supplies
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
My sony KP-57ws500 flashes green then turns off.
YOU HAVE A BAD GREEN CRT. UNIT IS NOT WORTH REPAIRING SINCE YOU WOULD HAVE TO REPLACE ALL 3 CRTS FOR THE UNIT TO SET UP PROPERLY.
Jan 12, 2009 | Sony KP-57WS500 57" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
