Question about Intel Motherboard
ASUS P4P800E-deluxe and dual channel memory
I have installed two pairs of Kingston kit memory sticks on my P4P800E-deluxe (2x1GB and 2x512GB) but the computer only shows 1.5GB. I have tried all types of different arrangements in the memory channels, but nothing works. Should I be changing something in the BIOS?
Any help you can give would be highly appreciated.
Thank you.
Wellesley Johnson
  • vsempere Jun 24, 2008
    I have just installed two 1G kingston modules in the first channel and another
    two 512M modules in the second one, well, the system reports that the
    total memory is 2944 M. Where is the other 128 M memory?
    I have read in the manual that the South bridge needs certain amount of
    memory. Maybe this is the cause. Does somebody know anything about this
    Thanks in advance.
AGP Memory hole, in the BIOS setup, was the cause of "lost" of my 128Mbytes of memory.
Posted on Oct 25, 2008
  • 103 Answers
I'm not totally sure whether this would make that big of a difference or not, but the ASUS QVL for that motherboard does not list both those particular memory modules (Kingston 1GB) as being supported for double dual channels, only for single dual, or for single channels only and there is some note in the memory specifications and setup configuration about not reading all the memory due to some bridge or another, but still optimizing all the memory.
You might want to ask ASUS about it.
Posted on Dec 16, 2007
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Hi I have inherited an asus m2n mxse mobo with an unknown cpu in and fan,supposedly working. I have a stick of 1 gb kingston ram (DDR2-800 KVR800D2NG) in 1 slot. The board won't start, even into bios,it...
pj, the manual specifies, See page Viii and page
1-3. for the memory supported by the M2M-MX SE MB uses: Dual-channel memory. 2x240-pin DIMM up to a max of 2GB. Non-ECC 800/667/533 MHz
All dual channel memory comes in pairs. Also see page 1-13 before installing you're memory.
SS memory should be inserted into DIMM_1.
DS memory should be inserted into DIMM__1 and DIMM_2.
Provided below is Asus updated QVL list.
If you wish to install Kingston you'll need to buy,
KVR800D2NG not KVR800D2N5 as shown in the QVL list. Ran a search through Kingston’s site. Seems the memory you bought is not supportive for Asus MBs.
Feb 12, 2010 | Computers & Internet
Dead ASUS P4P800e-deluxe motherboard. The verbal POST says ''System failed CPU test''
Try cleaning up the motherboard, remove and clean the heatsink, CPU fan, RAM, etc. Might be caused by dust that have build up inside. Hope this helps.
Oct 02, 2009 | ASUS P4P800E DELUXE Intel P4 865PE 800FSB...
I'm Confused about Dual-Channel, How to Activate/Enable it?
Check your user manual for the type of memory you can use. If your computer could use dual channel memory, I think it would come that way. Dual Channel is a pair of special compatable memory modules and only come in pairs. To buy two unpaired memory modules and hope to run them as Dual Channel is wishing too much. If they work, you're lucky, but most likely they will not work as dual channel.
If you are using those two different memory modules and they both work for a total of 3 GB then you can not do much better.
How many memory slots are in your Asus G1 notebook?
Jun 14, 2009 | ASUS G1 Notebook
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
Suitable dual-channel memory module for ASUS P5N-D
Hi hellinme, since you want to go with Kingston, can I suggest this link.
I picked the memory you wanted. DDR2 800MHz. Than picked, Asus for the board & scrolled down through motherboards till I came to the P5N-D board. Listed there will be kingston hyperX memory suggested to work the best for the motherboard.
The memory, KHX6400 D2ULK2 2G(2x1gb), is not listed.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
May 27, 2008 | ASUS Computers & Internet
Motherboard Missing instruction manual for dual mode memory
Your instruction manual for the mother board should have this, however, with dual-channel motherboards, you will want to fill the same colored slots together if you have dual-channel capable memory, otherwise you'll want to fill in the off-colored slots first.  ASUS has it's manuals online, so if you've lost yours you should be able to download a pdf of it from their website.
Nov 09, 2007 | ASUS A7V8X Motherboard
Intel Motherboard Logo
78 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
