Aircon dryer Will an air-conditioning sytem cool if the dryer is installed the wrong way round
  • 262 Answers
No the filter is a one way filter unless it is a by flow filter which is the best it is installed on the little line (liquid line) you need to switch the flow on this filter dryer.
Posted on Dec 16, 2007
To clean the filters
Instructions on how to clean the filters are in any air conditioners user guide, a scheduled maintenance section. Just choose the necessary one according to your air conditioner make and model, download it and find the needed information Air conditioner hvac user manuals
Mar 21, 2014 | Heating & Cooling
The passenger side aircon is not cooling in my xc70 volvo 2006
The control unit is not responding check with volvo for a firmware update to b installed on your vehicle
Dec 04, 2012 | Air Conditioning and Heat for Volvo XC70
My car said "engine hot
Full coolant level does not mean your engine cannot overheat. You need to fix the problem as overheating will destroy the engine if not addressed.
The radiator cooling fans must be working, as must the water pump. The thermostat must also be working properly.
There must also be no air in the cooling system as air locks will impair water flow. When cooling systems are drained fully or partially and re-filled air in the system must be bled out using the correct bleeding procedure for the particular engine/cooling system. Failure to do this properly will lead to overheating.
If you ONLY see the overheating warning when running your aircon you need to check that the electric radaitor fans are kicking in at idle when you switch on and run the aircon and the engine has been warmed up some. If they do not start operating when the a/c is running you will get an overheating condition in normal driving conditions.
If the radiator fans are operating normally and you still get an overheating warning when the aircon is on or off the most likely culprit is a faulty thermostat in the engine's cooling system which will need to be replaced.
If you have either a faulty thermostat or if the water pump in the cooling system fails you will get continuous overheating whether the aircon is on or off.
Sep 05, 2011 | 2006 Chevrolet Impala
Split air conditioning sytem- not cooling very well (maybe gas problem). previously had icicles coming out of fan. How much should this cost to repair. 5 year old system.
On average a service call should be around $75 to diagnose what's wrong. If it is low on freon there must be a leak somewhere and will have to be found and repaired before more freon is added. Cost would depend on the amount of time it takes to find the leak and if it can be repaired.
Mar 21, 2011 | Electrolux E23CS75SS Air Conditioner
What could be wrong with a 2004 honda element when the air condition wont cool
look for the drier in the aircon system, mostly it is located behind the bumpers, check on the see ythru gauge if it has bubbles, if it does your freon is low...
Aug 17, 2010 | 2004 Honda Element
What could be wrong with my aircon unit? Water dripping sound
Your coils need cleaned, and change the filter too. make sure drain is not cloged also.
Jul 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
96 suburban air conditioning blows out cool in front hot air back
Am investigating same problem. Download the free technical manual and you can find a diagram for the air mix door. If this doesn't shut you will be getting lots of heat through despite the cooling of the Aircon. I don't know how to get at it or fix it but it describes how to run diagnostics - you don't need specialist tools for this. Also a blocked pollen filter probably won't help.
Jun 30, 2009 | Chevrolet Suburban 1500 Cars & Trucks
1995 deville, how to charge the air condition
This is a great site for aircon FAQ's:
It can show you how to check what gas you are using, how to check the system and how to top it up if neccessary, there is plenty of info and video if you need it.
I found it a great help when my wife had problems with the aircon in her Pontiac.
Sep 26, 2008 | 1994 Cadillac DeVille
Air conditioning
most thermostat wiring is 4 core, because installers use phone cable -its cheap- but there is no accepted color code, and some systems use 2, or 3, or 4 of the wires.
there should be a standard.
terminals on thermostats and furnace, aircons are labelled, but the labelling is often contradictory. some thermostats have function to control the fan separately, some for the same aircon dont.
the manufacturers web site for your aircon,
should give a detailed explanation in install instructions which terminals are open on rise close on rise, heat/cool and how they are connected
the new thermostat should detail which of its terminals match those of the aircon.
test the cable before installing anything at the aircon or thermostat, a lightning strike can have shorted things normally impossible, and the lowV thermostat line could be at lineV and trash anything or anyone connected to it,
  • Lightning strikes are very unforgiving, please be careful, even if the lightning touched down yards away the voltage at large distances from the strike can be 10KV
  • paranoia impels me to recommend an electrician with test equipment for the lines, outside unit, cables and inside units, its better to check and be wrong, than not check and be wrong.
Jun 22, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
