Question about ViewSonic VA720 17" LCD Flat Panel Monitor
My Power cord no longer works properly. Where can I purchase a replacement?
  • 1,684 Answers
We carry them in stock for $17.95 plus shipping.
Buddy
Corporate Computer
tech@ccl-la.com
Posted on Sep 24, 2009
I have a Crosley dryer and we replace the plug it ran and now it has no response
Good Evening striver ajj, thank you for your post!
Based off the information you have provided your Crosley dryer will no longer operate. Sounds like you could have a problem with a faulty power cord or control panel. I would recommend consulting with a technician for proper diagnosis to be completed this will help avoid any unnecessary part purchases. Hope this information is helpful. -Matt
Nov 14, 2014 | Dryers
I have a Bellin router and sometimes turns orange sometimes for half hour or more.What could cause this.
1).This problem may be due failure of power supply from the power card. That means power cord may not be working properly. Kindly purchase the new power cord and try to solve your problem.
OR
2).Disconnect the power supply and disconnect all other cables from the router. The switch of power supply button of router may not be working properly. Kindly try to press the power supply button and release again and again for 3 to 4 times. Then connect all the cables and power cord. The problem may be solved.
Aug 16, 2012 | Computers & Internet
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
The power cord was crushed and no power is getting to the tv. Is the plug able to be replaced as this has happened below the splitter???or whatever the thing is on the cord. thanks Shelley
If the power cord comes off the television you can replace it with a standard power cord. You have to tell the Radioshack employee how many volts and hertz. That should be on the back of the television. If the power cord does not come off the television you can find someone perhaps a tv repair guy that can attach another power cord to the one on the television. My dad actually did that when his older television would no longer power on. He took the bottom part of a power cord from a fan that was no longer working and attached it to the television's power cord. It has been working like a charm ever since for years.
Sep 28, 2010 | Televison & Video
Power cord no longer works on my averatec 2500
The type of adapter you have is a 19V 3.16A 60W?
Power cords are available at any nearby stores, they are not expensive. Check with walmart and radio shack.
or go to this page and you should be able to purchase it online.
http://www.google.com/products/catalog?q=power+cord+laptop&hl=en&cid=2956081618901309040&ei=RkkBTIe3IIjONb_e9JQJ&sa=image&ved=0CBQQ8gIwAjgA#p
Hope that helps. please rate me :)
May 29, 2010 | Computers & Internet
ATT wireless router not working
All of the things you mentioned here are correct. But if you can purchase a power adapter with the same specs as the original power cord that came with the router it should work too.
Aug 17, 2009 | 2wire 2700HG-B Router (2700HGB)
I need to move the power cord from floor to ceiling
I would recomend you purchase a "heavy duty" (12 guage) short extension cord for appliances. You could remove the face cover and modify the unit so the cord goes up but I don't think it will be much longer nor will it be as safe. The cord has a moulded gromet mad onto it so you may only be able to move it to the side. You would have to make a similar mount on the unit (cutting metal and plastic parts to hold the cord properly. The short HD cord will not cause any loss in the units operation,warranty or unit life.
Aug 04, 2009 | LG Art Cool LA121HNP Split System Air...
Duet 4.4 Washer (not steam) power cord too short
Hi, you might be able to find an 8 foot dryer power cord at your local building supply or hardware, or electrical supply store. It will be labelled for a dryer. First look at the dryer receptacle. The cords come in two types, 3 or 4 wire, so get the one that will match youyt receptacle. The wirte should be # 10 minimum.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Jan 06, 2009 | LG Phenom Express
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
79 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
