Question about LG VX8300 Cellular Phone
What is the max memory card size the vx8300 can
What is the max memory card size the vx8300 can use. I have a 4gb that the phone refuses to format??
Memory card full
If you already used the card in the same camera, the only thing I can think of is you did switch the lock switch on the SD memory card. Or there must be one or more protected images on your card. If the card comes out of another camera be sure it is a SD or a SDHC card, not bigger than 16 Gbyte because a SDXC card would be one size to big. The manual says max card size 16 GB
If you accedentely formatted the card in the PC (or MAC) it could be you did put a format on the card the camera does not understand. Most camera's use FAT (max 32) and never NTFS.
Try to format the SD card in your PC.
Nov 04, 2013 | GE X500 Digital Camera
I insert memory card in to my touch t-mobile but not supported say format memory card what shall i do right now?
Hi Teddy.
Regarding the issue you have with the memory card & the error message showing on the phone. It could be that the memory card you're using is not compatible with the phone model that you have.
Every phone has it's own maximum size of the memory card compatible to it.
E.x. A phone could only support up to 2Gb, but your memory card size is 4Gb.
You could contact your phone manufacturer & ask the maximum size of the memory card allowed for your phone.
If your memory card is compatible with your phone, you could just proceed in formatting the memory card on your phone.
**WARNING**
Formatting the memory card will erase everything saved in it.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 21, 2013 | Kingston Secure Digital MicroSD /...
My memory card is reading on my nokia 5130 nut not on samsung corby g-3650 ?
Hi,you need to format the card before using on another phone..
additionally some phones has a limitation of max 2 or 4 Gb card size use..make sure your SAMSUNG can handle the card you had..try to use smaller size card..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me
to continue f
or Helping out the Community :)
Thanks
Aug 16, 2011 | Cell Phones
What is max size Memory Card for RAZR V3m?
MOTORAZR V3m microSD
Up to 1 GB MOTORAZR V3m (Sprint) microSD
Up to 2 GB
Mar 27, 2009 | Motorola Mobility RAZR V3m Cellular Phone
8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
Jan 26, 2009 | LG Vu CU920 Cellular Phone
LG Vu Cellular phone memory card does not read.
I had same problem-you must push memory card ALL the way in until it clicks!! Also, make sure connection under settings is set to "mass storage"
Dec 27, 2008 | LG Vu CU920 Cellular Phone
V3i card formating
no solution... need a 512kb sdmini card... that is the MAX supported size.. i have the same thing on mine... i had a 512 card tho and it formats fine and works. the 2gb card wont even be recognized by the phone..nevermind format. i can also format it on my pc but that does no good
good luck
512 sd cards are 5 bucks on ebay now ! get one
or two
Nov 04, 2007 | Motorola Mobility RAZR V3i Cellular Phone
LG VX8300 Cellular Phone Logo
194 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
