Question about Technics SC-DV290 System
The fuse inside the system went, what fuse shall i replace it with?
    Scholar:
  • 113 Answers
You need to replace it with the same specs of the bad one! On the bad fuse it will have the volt and amps ingraved on each end. Look with a magnified glass if you can see it! It should say something like 2v 1a or 3v 1 amp..v = volts, and a = amps. If this helped you please give me a thumbs up! Thanks
Posted on Sep 24, 2009
    Sergeant:
    Champion:
  • 262 Answers
A 3mp fuse
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
Aug 19, 2017 | Emerson Microwave Ovens
The gas gauge,speedometer,and temp gauge does not work, what shall i do to fix it.
Those gauges get power from a 10amp fuse marked CLSTR and a 10amp fuse marked BCM/CLU. The fuses should be in the fuse box inside the car.
Have you checked those fuses to see if they have power ?
Apr 09, 2013 | 1999 Pontiac Sunfire
Is there Liebert NFORM software for normal PC windows 7? and if there please send me A demo .
Liebert ® Nform Software
GUIDE SPECIFICATIONS
1.0 GENERAL
1.2 SYSTEM REQUIREMENTS
A. All material and equipment used shall be standard components, regularly manufactured and available and not custom-designed especially for this project. All systems and components shall have previously been thoroughly tested and proven in actual use prior to installation on this project.
B. The manufacturer will furnish or supply a site-specific Critical Infrastructure Management software system based on customer requirements. The system must be a software-only solution; no substitutions will be accepted.
C. The system architecture shall consist of network interface cards that will be installed in all critical infrastructures that at a minimum support HTTP and SNMP simultaneously.
D. The system shall receive SNMP traps from managed equipment and display the alarm notification in a graphical user interface.
E. The system shall be based on SNMP Open Protocols and integrate seamlessly with Emerson Network Power, Aperture® software suite and Network Management Systems.
F. Open protocol support shall include:
· HTTP(s)
· TCP/IP/v4, TCP/IP/v6
· SNMP v.1, SNMP v.2
G. The system will have the capability of being remotely monitored and managed 24 hours a day, 7 days a week by the manufacturer.
H. The system shall have the ability to be deployed world-wide.
I. The system shall operate as a client-to-server application.
J. The Web interface of each managed device shall integrate directly into the system.
K. The system shall support Enterprise level databases including Microsoft SQL.
L. The system shall support exporting of all recorded parametric trend data.
M. The system shall operate on a server defined by the customer. Specific server brand or function is not permissible.
N. The system shall support virtual server environments by default.
O. The system shall include at no additional cost one (1) year of Software Assurance.
May 09, 2011 | Liebert OpenComms Nform for PC
I went to game and they cleaned my disk then i went back home and tried and i didnt work what shall i do
Try different games on it and see if the system is reading any of the games. If its not then the laser is bad and the drive will need to be replaced.
May 01, 2010 | Microsoft Xbox Console
2004 Ford Focus battery went dead had to replace,now no power to
found out there is a 10 amp fuse on the back of the radio itself,replaced it and all is well
Sep 17, 2009 | 2004 Ford Focus
Fault
the only thing you can do yourself is leave the set unplugged for over an hour, this will reset it to factory settings. If that does not do the trick it will need to serviced. Chances are if it is a rear projection set that the convergance board is dead. This would be more to fix than the tv is worth.
Jul 07, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Hp scanjet 3970 won't power on
Is the AC adapter getting warm when it's plugged in?
No fuses inside.
Jun 10, 2009 | HP ScanJet 3970 Flatbed Scanner
ONKYO HT R320
The fuse is internal. You'd need to take off the cover and look inside it. If you did that and took it to an electronics repair shop, they should be able to tell you where the fuse is by looking and help you find a replacement.
May 16, 2008 | Onkyo SKS-HT510 System
Technics SC-DV290 System Logo
146 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
