Question about Submersible Systems 1/2HP 2WIRE SUBMERSIBLE PUMP
Where do I find Mastercraft submersible pump parts in the Edmonton area. Part #560799, impeller required
    Sergeant:
  • 399 Answers
Check on the net
Posted on Nov 14, 2009
Where can i get a part for a ps200
http://www.tmsequip.com/part/wacker-neuson-part/wacker-neuson-part-0152391-impeller-ps2-400-500-psa2-500/
Sep 26, 2014 | Wacker 2" PS2400 Submersible Pump...
Need impeller
Try: http://www.ebay.com/itm/115-VAC-75-GPH-P60-SUBMERSIBLE-FOUNTAIN-PUMP-2-1253-/380224882001
You can get the impeller with a spare motor for less then $20.00. Your local Low's store may have one in stock.
Aug 04, 2013 | Cal Pump Cal Fountain Pump P-60
May tsurumi submersible pump is overheating.do i need to oil on the plug of the of the pump? Is it ok if increase the discharge diameter? What will be effect of it? Hope u could enligthen me on this...
This is a single phase induction motor. You mentioned it is overheating. You did not mention whether or not you had easily turned the pump by hand. Pumps overheat for several reasons but these are the top 4:
1. The head pressure is too high as in the pump is being used to pump water higher than the head level of the pump. (Lift distance to high)
2. Low utility or generator voltage. Lower than the pump rated input power requirements.
3. Bearing Friction or motor / bearing mis-alignment ( 3. Pump is sitting in debris while pumping and the pump inlet is being blocked by debris. Also... if it sat in clay and the clay dried inside the pump it can restrict water passages to the point that the pump just can not pump enough water to stay cool.
Does it overheat when pumping at 15 feet or less? I note that this is actually a 1/2 Hp pump. The max LIFT distance for most 1/2 Hp Pumps is 23 feet or less using a 1 1/2 in discharge. The lift will be even less with a 2 inch discharge outlet. As for oiling the pump... Most submersibles always have oil above the impeller and it usually does NOT leak out unless the seal between the impeller and the motor stator / aramture has failed letting water into the winding. That plug you mentioned is for checking to see if water is in the winding area. If you pull the plug and get water the seal is bad. Hopefully you can save the winding.
You asked what the effect would be if you went to a larger discharge diameter. This will give you more volume but less head / lift distance.
Thanks for choosing FixYa.
Kelly
Apr 06, 2011 | Tsurumi Pump s Submersible Water Pump ...
Pump turns on but the impeller does not turn. I can turn the pumpo on but until i make the impeller move it will not turn. It is straining trying to get the impeller to turn. Once the impeller is turning...
sounds like your problem is the centrifugal switch inside the motor housing or the start windings in the motor are bad. Not sure about your peticular pump but most submersibles are filled with mineral oil, take care to save it when you disassemble, it needs to go back in
Jul 02, 2010 | Little Giant ES40D120 410 HP 60 GPM 10' ...
I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Aug 24, 2009 | Little Giant Submersible Fountain Pump
I have an Simer pedestal pump and the part that connects to the impeller from the motor is broken. I can not find a repair part or part #. Can you help me? THX
there is no repair parts all you can do is change the pump,, go with a submersable zoeller pump best on the market for the price aprox 100,
Mar 15, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
I have versa gold submersible pump, it works intermittently. There is enough water in the pond and it is submerged
Intermittent running usually points to intake or impeller obstruction. Remove the impeller screen and cover, inspect the impeller, the screen the discharge exit point for debris. Unlike other brands the impeller is not replaceable if worn or damaged.
Jan 25, 2009 | NEC Versa Gold Submersible Pump
Submersible Systems 1/2HP 2WIRE SUBMERSIBLE PUMP Logo
355 people viewed this question
Top Submersible Systems Tools & Hardware - Others Experts
Are you a Submersible Systems Tool and Hardware - Other Expert? Answer questions, earn points and help others
