Question about Ruud UBHC Air Conditioner
My blower on my heat pump will not cut off; It is set to automatic and this morning I turned the setting up to 90 and it is still blowing
  • 3,361 Answers
Check the thermostat first. <ake sure it is not set for FAN ON vs AUTO mode. If it is OK,Replace the fan relay. It is stuck in the ON mode.
Posted on Sep 24, 2009
My ruud achiever 90 works fine it's producing plenty of heat. It's just that it only shuts down for a few seconds before it reignites then starts blowing again. It's almost continuously on.
Most likely:The thermostat is telling it to come on. If it continues to run with the thermostat set to off,the ignition relay is stuck in the on position, when the ignition is on the heat sensor will turn the blower on on matter what.
Dec 12, 2014 | Heating & Cooling
Heat or a/c blows only one speed /high only
90% of the time it is a faulty blower motor resistor. The sound when you turn off your HVAC is probably a squeaking from the blower motor fan or the pressure dissipating internally from the AC system. These are normal sounds.
Jan 05, 2012 | Cars & Trucks
I have a programmable thermostat that I set to 68 at night. The system turns on and runs, but when I woke up this morning, the tempterature in my house was 58. I felt near a vent and it felt like it was...
Hello, sounds like the units high limit switch is opening and shutting down the burners. When this happens the blower motor and inducer motor will run nonstop....and this is why you probably just felt cool air blowing from the air duct. Usually a dirty filter, blower wheel or weak blower motor can cause the units limit switch to open.
Dec 01, 2011 | Heating & Cooling
Heater wont blow hot air in my 1998 Lincoln Navigator
the computer that controls the deflector motor are not responding and opening the door for heat, I'm sure you have climate control,check the temp setting sensor to the computer input first
Nov 01, 2009 | 1998 Lincoln Navigator
Split system blower not blowing any air on heat or ac
You maybe iced up. Turn of AC turn fan on and wait about 45 minutes. If fan is blowing air out of vents chances are you were iced up. Two reason for iceing up are AC coil dirty and low on Freon. You need a service tech to check your Charge on system. If you can get to the coil to clean it grreat. Spray it with water let it set and brush clean with a toilet stool bruch. It will not damage the coil. If it is to stopped up you may have to have a service tech chemicaly clean the coil. Fan motors do go out. ou realy need a service tech to check this Rusty
Apr 27, 2009 | Heating & Cooling
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
Rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Jan 27, 2009 | Heating & Cooling
Car only blows cold air
Check temperature heath controltemperature heather controlNTREPID Temperature/Heater Control 2000
Dec 04, 2008 | 2000 Dodge Intrepid
Over heat of vw polo
Hi, Try turning on blower, set to warmest setting.
If the blower is blowing cold air, the problem could be Water Pump needs replacing!
Sep 06, 2008 | 2001 Volkswagen Golf
Fan keep,s blowing
Your thermostat is calling for blower, your fan relay is stuck, or that model had a time delay blower solid state board on it which had the blower relay on it, and it could be bad. I would turn the power off to all of your system for a few minutes and see if this could make something happen.
Nov 20, 2007 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
