Question about Echo Rapid Loader, Trimmer Head
Wont stay running, replaced spark plug and air filter, starts but wont stay running
  • 437 Answers
Try mixing fresh gas mixture, any fuel over 30 days old is gone bad, this may help. Or the carburetor may need rebuilding, or the exhaust screen on the muffler is clogged up. Remember before taking anything apart use either PB blaster or Deep Creep on the bolts before loosening them.
Brian
Posted on Sep 24, 2009
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
2002 Blazer will not start. It fires and sounds like it is going to start every time I turn the key, but will not start. Sometimes it sounds like it starts, but dies immediately. (within 1 or 2 second
if you know its getting fuel then lest talk about spark check the spark plug wires and the spark plugs if you got spark see if your getting air check the air filter if its to dirty it wont start beacuse clean air wont come through
Sep 09, 2012 | 2002 Chevrolet Blazer
2002 ford escort zx2 replaced fuel filter, air filter, plugs, and MAS...why won't it stay running?
it could be down to your spark plug leads take the leads out one by one and get somebody to hold the lead to the engine [to earth it] NOT WITH YOUR HAND with something thats not conductive like something plastic then try starting the engine to see if a spark jumps from the lead and repeat this please dont do this with your hand its very dangerous enouf voltage to knock you out!
Aug 06, 2012 | 2002 Ford ZX2
For about a week my 2001 galant es v6 would not start right away. After 4 or 5 times it would turn over and stay running after i gave it gas. I went to start it today, it started but didnt want to turn...
YOU NEED A LITTLE TUNE UP.REPLACE FUEL FILTER, REPLACE AIR FILTER,CLEAN FUEL INJECTORS.REPLACE SPARK PLUGS AND WIRES.IF ENGINE STILL SHAKE YOU COULD HAVE FUEL PUMP OR FUEL PRESSURE REGULATOR PROBLEMS.
Aug 16, 2011 | 2001 Mitsubishi Galant
My 1986 Nissan 300zx wont start and run. It starts then sputters till it dies. If you play with the gas pedal it will run for longer but wont stay running. I replaced the fuel regulator, ignition coil,...
check for fuel compression, gas filter and try, a gas treatment, you buy it at auto zone the gas treatment is suppose to clean the jets . if you think is a valve issue then you should give it a compression test I would use the type gauge that screws to the piston hole and check each piston for compression.
good luck.
Feb 04, 2018 | 1986 Nissan 300ZX
Not running right
Verify the air filter canister for any foreing objects, change spark plugs, wires and fuel filter.
Jul 20, 2009 | 1994 Lexus LS 400
Gv 250 wont stay running
read my solutions on this site for clogged carbs.....Tim
Jun 01, 2009 | 2002 Hyosung GV 250 Aquila
New battery re-charged but still wont fire
Check for spark
If yes, it is getting FIRE, just needs AIR and FUEL
Give it a 5-second shot or two of Starting Fluid (Ether) through the Air intake (filter) and try to start
Does it kick and run really fast and then stop?
If not, pull the plug, clean and check for GAP of 2-3 matchbook covers. Retry. Does it run (or try to)?
If it does, Now we have to look at Clogged air or fuel filter or water in line(s)
Remove air filter. Try ether again. If it starts and runs, replace or clean air filter. Done!
If not... Replace AIR filter and Drain fuel into metal or Glass jug, take off fuel filter, open and drain fuel bowl. Replace fuel filter, refill tank, prime, give it a shot of ether and try again. If it runs, Done!
If it still will not stay running, but you can coax it by giving it a blast every 5-10sec, it could be linkage, stuck choke, throttle plate or jets. Give carb a good cleaning, check throttle plate (in carb throat between it and Air Cleaner) and.check Choke. Try again.
If it still will not run, take to mower mechanic.
Mar 26, 2009 | Garden
2000 toyota tacoma 2.4l wont start when cold
clogged injectors you need to put cleaner in the fuel to help get dirt and grit out of them some times (every 3 months).
I am assuming you are saying it will turn over but not fire and run when cold?
Jan 16, 2009 | 2000 Toyota Tacoma PreRunner
Echo Rapid Loader, Trimmer Head Logo
413 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
