Question about HP LaserJet 4600dn Color Printer
HP color laserjet 4600 dn printer How do I set
HP color laserjet 4600 dn printer How do I set it up to feed from tay 2 instead of tray one which is for manual feed. Right now, it always defaults to tray 1 and you have to double clikc the check button to accept feeding from tray 2.
  • anita_hunter Sep 24, 2009
    I figured it out - it was on "behaviors" and have all auto sensing turned off. Thanks - only took 2 hours...
  • 39 Answers
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Posted on Feb 19, 2010
I cant get my printer HP2055 dn to print letter paper..it just goes to the legal tray (3). I also can't figure out how to get to the menu on the printer to see if the trays are set correctly.
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
Feb 12, 2013 | HP LaserJet P3005n Printer
How do you make an hp color laserjet 4600 dn recognize a quill remanufactured cartridge?
In 35 years of doing this for a full time living, I have never seen worse products thany toner or developer than Quill.
I would not buy that stuff if they were the last manufacturer in this solar system.,
Sep 12, 2011 | HP LaserJet 4600dn Color Printer
How do i adjust the margins from the printer? HP color laserjet 4600 dn printer
Usually in "page preferences" in the file drop-down bar. Then use "print preview" to see if the page looks OK.
Mar 22, 2011 | HP LaserJet 4600dn Color Printer
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
Sep 09, 2009 | HP LaserJet 4600dn Color Printer
13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jul 23, 2009 | HP Color LaserJet 3500 Printer
Business cards get stuck in HP 4650
The card stock is most likely too heavy for the 4600. If you check the owners manual, you will most likely find this is "Out of media specifications".
Other color HP laser printers like the 2500 cannot move card stock well either.
HP will tell you that 'if the printer moves paper perfectly' it's not broken.
Mar 12, 2009 | HP LaserJet 4650 Color Printer
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
Envolpe feed problem
I would first off try cleaning the feed roll in that tray well. That really sounds like slipping.
Go through all your programs and make sure that the driver machine and program you are running has the envelope settings the same.
Be sure they all match. Example. Make sure all the programs you are running through, have the settings for # 10 envelope, consistancy is needed for running envelopes. They are problematic.
May 01, 2008 | Xerox Phaser 8500/DN Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
HP LaserJet 4600dn Color Printer Logo
918 people viewed this question
Seeker5211
Seeker5211
