Question about Electrolux Vacuums
How do I disassemble Electrolux oxygen? I need to adjust the cord re tractor.
  • 97 Answers
SOURCE: Electrolux EL7020A Oxygen 3 dead!
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Posted on Jul 31, 2008
SOURCE: Need source for Electrolux Oxygen parts!
Some parts can be found here: http://www.vacuums24x7.com/elox3ulcocav.html
Unfortunately they don't have the part I need.
Posted on Aug 15, 2008
  • 3 Answers
SOURCE: Electrolux EL 7001 Oxygen 3 power cord continually retracts
Tie a knot in the cord so it can't retract.
Posted on Oct 26, 2009
SOURCE: electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Posted on Nov 09, 2009
ThinkVacuums
  • 144 Answers
SOURCE: Need a new electrolux power nozzle model N106m
If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
Posted on Mar 23, 2010
How to replace electolux 7000 cord
These canisters are not easy to change the cord in. If you're somewhat handy and know how to disassemble the machine, it is more cost effective to just order a cord winder complete assembly and switch them out yourself! It's most likely less expensive than the labor and parts you'd pay to have it completed! I have them! Hope it helps! Thanks!
Aug 26, 2014 | Electrolux Vacuums
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
http://www.aerushome.com/storelocator/
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Electrolux Oxygen 3 model 7020A contols not working
You need to replace the hose itself. The buttons in the handle a very cheap and go bad all the time.
Aug 17, 2009 | Vacuums
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen 3
Most cord reels have a stop on it, it is a rubber wheel and when dust gets on the wheel, they won't always stop the reel. It would have to be opend up to get to the cord reel, then you could clean it out.
Jan 12, 2008 | Electrolux Z5935 Bagged Canister Vacuum
Vacuums Logo
720 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
