Question about Primavera Project Planner P3 (PRIMAVERAP3) for PC
Cannot open P3 projects with logos embedded in footer ( logo files are windows metafiles). P3 hangs up on opening layout; (then when closing P3, error message paraphrased "ntvdm.exe file is non-responsive" Logos were created by another user on another PC)
1. Go to My Computer
2. Go to Tools
3. Folder Options
4. File Types Tab
5. Find the file type "Primavera Draw" with the "PMT" extension
6. Delete this file type
7. Click on the "New" button to create a new file type
8. Enter "PMT" for the file extension and click OK
9. With the "PMT" file type selected, click on the "Advanced" button
10. Enter "Primavera Draw" in the box next to the "Change Icon" button
11. Click on the "Change Icon" button
12. Click on the "Browse" button and navigate to C:\P3WIN\P3PROGS\PRMDRAW.EXE
13. Select one of the two icons (I like the color one) and click "OK"
14. Click on the "New" button next to the "Actions" list
15. Type "open" in the box under "Action"
16. Type "C:\P3WIN\P3PROGS\PRMDRAW.EXE" in the box under "Application used to perform action"
17. Click "OK"
18. Click "OK" again
19. Click "Close"
20. Close "My Computer"
Posted on Dec 19, 2009
Suretrak 3.0b: invalid path or file name when I try to save file as something else
The error message about invalid path is referring to a missing logo file. In the footer, or header, set Logo to None, or find the missing .bmp file and place it in your default SureTrak Clipart folder and re-browse to its location.
Aug 04, 2014 | Primavera SureTrak Project Manager 3.0 for...
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
How do i fix an invalid path or filename error when saving
I answered this once, but it didn't seem to post. Invalid Path or Filename error is generated when a logo (.bmp) file is specified in the header or footer, but is not found in the default folder "Clipart," usually found under SureTrak in Program Files or Program Files(x86). Either set the logo in the footer to None, or copy and paste the missing .bmp file to the Clipart folder, then in the Footer (Page Setup, third tab) re-browse the logo setting to the correct location.
May 21, 2014 | Primavera SureTrak Project Manager 3.0 for...
Cant open outlook express hangs at blue logo window
Perhaps some files in your OE are damaged by virus or something else, you can try .dbx repair tool. It repairs .dbx messages up to 4 GB. Program repairs attached files, it's compatible with all supported versions of Windows. Tool finds corrupted .dbx, scans, analyzes and recovers it.
Dec 27, 2010 | Microsoft Windows XP Home Edition
Suretrak 3.0b: When I go to page setup on some projects and change the parameters and click ok I get an error message ?Invalid path or filename?. It will not let me change anything in page setup. I have...
When I had this issue it was fixed by removing any references to a logo that was not valid anymore. Go to Page Setup-Footer and if any of the Footer Blocks reference a Logo you can either click on each one, which will bring up a Flie Path selection box, or remove any logos by hitting the down arrow and changing from Logo to none.
Aug 03, 2010 | Primavera SureTrak Project Manager 3.0 for...
I want to prepare a letter head on plain paper, how I put my company logo & name, as well address on it, What I mean is how to put header & footer on paper?
Letter head on Plain Paper
Step1: Open a Microsoft Word Document File
Usually word creates a new document when the program is opened.
Step 2: Inserting Header and Footer in Word Document
Click on view and then Header and Footer.
Step 3: In a Microsoft Word document, choose Insert > Picture > From File… After selecting file, it will give you a browse file option, where you have to specify the location of the logo file you have created with desired resolution and size.
Step 5: Control-click on the placed image and choose Format Picture from the pop-up menu.
Step 6: Inserting text into the Header and Footer
To insert text into your letterhead, simply select the font style and size of the text you require, then enter the text into the header and footer box.
May 18, 2010 | Microsoft Computers & Internet
I loaded MS Office 2003 on a new laptop running Windows 7, only to find that Word opens as a blank page with no toolbars, rulers etc - only the writing area. Excell works ok
The Word 2003 Window When Word is first started, a new blank page titled Document1 is opened automatically. This is a fresh page where you can begin typing a new document.
  • At the top of the window is a row of menus, including File, Edit and View.
  • Below that row of menus is a row of buttons for various tools (collectively called the "toolbars") to use in creating and editing your document.
Layouts in Word 2003
Normal - Normal is the default Word 2003 view. It shows just the text that you are working on, without margins or header and footer information. It doesn't differentiate between different pages of text.
Web Layout - The Web Layout displays the document as if it were a web page
Print Layout - The Print Layout shows the entire page you are working on, including margins, header and footer information. It shows the layout of the text on the page the way it would be displayed if printed.
Feb 05, 2010 | Microsoft Office 2003 Small Business...
WHEN I TURN M ON MY PRADA PHONE KF900 IT JUST FLASHES THE PRADA LOGO. HOW CAN I FIX THIS?
you can't fix that .. it's an embedded logo for Prada... unless you can change the wallpaper of the phone you should be able to ... for now ..it's a logo for Prada .. like Windows XP you can't change their logo
Sep 18, 2009 | LG Prada KF900 Cell Phone
Missing WMF Graphic filter
I had the exact same problem and couldnt figure out what was going on...but I had a freak fix. I don't know how, but when I installed disc 4 (Picture It! 2000 Setup and Picture Disc) and disc 5 (Additional Art), I was able to access the program again. Hope this helps!
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
261 people viewed this question
Top Primavera Computers & Internet Experts
Tom Chichester
JEfromCanada
john smith
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
