Question about Toshiba e-Studio120 Copier
My copier displays a flashing "H" then a flashing "4" error code
    President:
  • 1,653 Answers
The H4 error is related to the Fuser Unit not reaching the correct operating temperature in the correct time. You can try clearing this error with the following:
Make sure that the machine is switched on and the error is displayed. Enter the Service Mode by pressing the following keys # * Clr *
Enter 14 and press Start. Then power off the machine, wait 30 seconds and then power back on. The error should have cleared. If not then you will need to call in a service engineer.
Posted on Sep 24, 2009
My copier is displaying flashing 4 and H
press the start button (big green button) , to see the next part of the error code ,
a simple reset should be able to fix this , so depending on your copier model, and the rest of your code ..........
Aug 21, 2014 | Office Equipment & Supplies
Tip
What to do to get your Whirlpool dishwasher to start when the light keeps...
<span>Hello,<br /><br />To reset the dishwasher push in this order the,<br /><br />HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF<br /><br />the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??<br /><br />example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4<br />7 flashes then pause then 7 flashes its displaying the error code#7 ect ect<br /><br /><br /><br />GENE</span>
on Sep 06, 2011 | Dishwashers
ERROR D-08-224 ON DISPLAY
Error type D08: Master making unit not setError point 224: Master making unit is not set (both the safety and lock sensor are OFF)
Try this: Set the master making unit in place.
Aug 15, 2012 | Riso Office Equipment & Supplies
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Estudio3500 spanner flashing call service, how do you find what the error code is
When your copier is displaying an error the code will be found in the top right hand corner of the display. It will be a mixture of letters and numbers and will be 4 characters. If the copier is not displaying an error code, holding the c and 8 button will make it appear.
Sep 24, 2010 | Toshiba E-Studio 3511 Color Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
Error code: H 4 flashes.. Nothing works
H4 PRESS START KEY THERE WILL BI A SUB CODE LIKE 00.THAT IS HEATER UNIT TEMPERATURE PROBLEM.RESET IT BY THIS PROCEDURE.
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
BY MIAN JEE
Oct 23, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316
enter the following code.
cancel -- interupt -- zero -- interupt - the display should switch off then enter 14 and push the copy button- copier should reset if not heater lamp could be blown
May 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Flashing error code
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 20, 2007 | Toshiba e-Studio120 Copier
339 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
