Question about Sport & Outdoor - Others
I need assembly instructions so I can put my reel back together.
    Problem Solver:
  • 10 Answers
Have you rang the reel makers,they would send you a print out for a small fee or you can go online to www.mikesreel repairs.com i have printed off quite a few for my own use. hope this helps.regards barry.
Posted on Sep 29, 2009
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Where can i get manual for assembling cardinal models10 fishing reel
do you till have the box it came in.many reel companies printed the diagrams on the inside .
Mar 28, 2015 | Abu Garcia Cardinal S Spinning Reel, Reel...
Put a okuma tundra tu-80 reel back together?
Okuma Fishing Customer Service
Here is a link to our a customer service. Click the "Contact Us" tab on this page and give them a call they are very helpful folks at Okuma.
If you need your reel repaired start here at The Reel People Home
Oct 19, 2014 | Okuma TU-1002-80 Tundra Spinning Combos
Pull cord all the way out vacum doesn't start. Push the recoil switch for a second then it will start. Bad connection or new cord needed? Also how do you reinstall the coil? Thank you.
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner2_bing.gif. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel. If you haven't already purchased one, here's a direct link to the exact cord that's needed for your S514:
Miele Cord Reel For All s500 Series #05240304
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter cartridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher position, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and components that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Apr 15, 2010 | Miele S514 Solaris Bagged Canister Vacuum
Repplacing power cord on Hoover Wind tunnel (not self propelled)
I am thinking that the cord goes in on the back, just below the handle. Remove the handle, then from the front, remove the tool holder(#8), then you can get to where the cord comes in and hooks up.
Feb 12, 2008 | Hoover U5753-900 WindTunnel Bagless...
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
Sport & Outdoor - Others Logo
82 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
