Question about Nintendo Wii Console
My wii wont turn on
I did not use the wii for almost 2 months and as i was just about to use it yesterday, it wont turn on. I tested the adapter by checking if there are any voltage coming out from it and i think its working fine.
Any suggestions on what to do?
  • 152 Answers
If your console still has a warranty, send it in for Nintendo for repair. Have any other comments then post in the add more details section of the question to post any more comments or questions.
Posted on Dec 21, 2007
Wii wont turn on
Try this:
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.Reset the AC adapter by following steps below.
Jun 27, 2012 | Nintendo Wii Console
My xbox wont send any message how do i fix it?
Jun 25, 2012 | Microsoft Xbox 360 Elite Console
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
I have had my laptop for 3 months - yesterday it was working, today it wont turn on. I have checked battery pack, changed fuse, changed plugs etc and nothing! Please help! :o)
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 15, 2010 | Acer Aspire One PC Notebook
My wii was fine last time I played but now it wont turn on tried unplugging and plugging it back up but didnt help
Hi there, you could try the following:
  1. Try unplugging Wii from the power for a full 2 minutes, plug back in and power up and test (This resets the Power Adapter).
  2. If this does not resolve it then it may need to be repaired so contact Nintendo here.
Please see here for for information on Power issues with the Wii.
Cheers
Apr 04, 2010 | Nintendo Wii Console
Last time i used it it was fine and i went to turn on my wii and it wont turn on
Cheers
Apr 03, 2010 | Nintendo Wii Console
I purchased a Wii console about 5 months ago. I never played the thing because I dident have any games. I just recently got a game, went to turn it on and there was no lights and it wouldn't turn on. I...
First, Check your wii adaptor, In normal conditions the wii adapter provides the output 12volt. You can test the output using multimeter or a 12volt lamp.
then
plug it into the outlet, If the light is still off/flashing, disconnect the AC Adapter unplug from the wall outlet, wait 2 minutes and plug it back into the outlet. Turn the console power ON.
hopefully this help..
Mar 05, 2010 | Nintendo Wii Console
Wii worked fine yesterday. Will not power up
This is a common problem with the Wii. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. It happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 14, 2009 | Nintendo Wii Console
We have had 2 wii's stop working in the last 2 months. Just doesn't turn on anymore. Is this happening to others?
Yes other people do have this issue also. Usually just the power adapter is broken. Usually you can fix the power adapter by "resetting it". This involves unplugging both ends and leaving it unplugged for 2 mins. If that still doesnt work you can call nintendo @ 1-800-255-3700.
Aug 05, 2009 | Nintendo Wii Console
Wii won't turn on
I called the Wii 800 number, and it said to unplug the a/c adapter from the wall and the unit for 2 minutes, and this resets it, it fixed mine.
Sep 05, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
