Question about NorStar Meridian M7310 Phone
Can't remember, what 2 terminals I punch down for paging? Was thinking is was the violet / blue pair, but thats not it. HELP! Chuck
    President:
  • NorStar Master
  • 860 Answers
It depends on the system type, on an MICS the external page is on the yellow/blue pair of the second connector (right above the MOH pair).
on a CICS, it the violet/brown of the second connector (right below the MOH pair).
Posted on Sep 24, 2009
Testimonial: "the paring sounds VERY familiar1 Will try in , and see what happens! Thanks"
Help with element on a wta2000 dryer
Terminal block goes:
1 white/brown
2 light blue and dark blue
3 not used
4 black/white and Black (t/stat)
Element
Far left pair terminals - black(t'stat) and black from loom
Right pair of terminals - red
Single terminal - blue from reset stat
Feb 18, 2013 | Bosch Dryers
I want to install a new switch in my Superior scms 10 L miter saw but I need a wiring diagram to put it all back together again.(2 blue,2brown & one grey wire.When I took it apart I did not mark the...
Denis use a meter on the switch. Measure resistance / continuity. Find the 4 contacts that are made when the switch is actuated. There are 2 terminals for blue and 2 terminals for brown. The terminals are paired so that each of the 2 terminals is made when the trigger is actuated. Blue to blue... brown to brown and grey will be the last terminal. It will not matter which side of the switch you connect the wires to as long as you pair up the colors. My concern at this point is the gery wire. If it is piggy backed to another terminal and you disconnected it this can be a problem. I believe the grey wire is for actuation of the brake. If this does not help you feel free to seek other experts. I do not think your going to be able to locate a wiring diagram without the aid of the products service center.
This is my experience:
http://blog.fixya.com/index.php/2010/05/award-winning-service
I only answered to try and help you due to the fact I know getting the wiring diagram will be a difficult task.
Thanks for choosing FixYa,
Kelly
Jun 30, 2011 | Garden
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
How do I replace the chuck on a bosch 1199vsr?
If there is a chuck bolt in the center (where the bit goes) remove it (left hand thread). The chuck is threaded onto the splindle(right hand thread). On some of those drills they have a small hole in the housing that lines up with a hole in the spindle. Put a pin punch in to lock the shaft so you can unthread the chuck. If you clamp a 3/8" allen wrench in the chuck it acts as a good handle. If there are no holes to lock the chuck, if you lay the drill on a bench and give the allen wrench a sharp blow with a rubber mallet it will unthread the chuck. If the chuck is damaged and will not hold an allen key you will have to cut the spindle off and replace the chuck and spindle.
Hope that helps
Jan 27, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Need the wiring diagram for a sony car radio CDX-GT32W
GRAY PAIR:SPEAKER
GREEN PAIR:SPEAKER
WHITE PAIR:SPEAKER
VIOLET PAIR:SPEAKER
BLACK:GROUND
RED:IGNITION CONTROL
YELLOW:12 VOLTS MAIN
LIGHT BLUE AND STRIPED BLUE:REMOTE OUT MAX .5 AMPS
Sep 20, 2009 | Sony Car Audio & Video
Adding new extension to Nortel Norstar Meridian Phone System
They should have terminated your voice on a block in your phone room. If that is the case you now need a punch down tool and a spool of cross connect wire. You would punch down one side of the cross connect wire on the tip and ring of the switch pairs and the other end of the cross connect wire on the blue pair of your station cable.
Jan 15, 2009 | Lands Phones
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
NorStar Meridian M7310 Phone Logo
111 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
