Question about EA Sports Cricket 07 for Windows
After installation they are saying they can't locate the C/D
My audio stopped working after I got a virus, I got rid of the virus and wiped the compter clean. The whole thing runs like new except my realtek high def audio controller says error code 10. I've...
Try installing it manually. Right click computer icon in desktop or start menu -->choose manage --> go to Device Manager --> Find the Audio device that has a Exclamation mark, Right click on the icon and choose update drive. A Hardware update wizard will pop-up tick the last circle that says no, not at this time ->install from a list of specific location ->Search for best driver in these locations tick the include this location in search box and then click Browse.. Choose where the Audio driver is located (either the driver CD or in your computer) and click next.
Sep 13, 2011 | Toshiba (4CH-VOUT) Sound Card
Hello, My laptop model is y410, now i instal os in windows 7 32 bit after i instal NVIDIA VIDEO SUPPORT DRIVER this is not instal in my laptop final thic say instal locate folder in not available in...
try to download driver that support the video driver (win 7 driver for nvidia ) or you can locate the xp driver on your hard drive than click ok
Jan 16, 2011 | Lenovo 3000 Y410 Laptop
I am installing a 3-way dimmer switch. The installation instructions only describe placing the switch at the location that has always has 120 volts. Is it possible to install the 3-way dimmer switch at...
Yes. The dimmer can be installed at either location - I think the instructions only describe the one location just to attempt to keep it simple.
To connect it at the other location, use the instructions you have, except where it says to connect to the house-wire that has 120-volts on it (connected to the breaker), instead, connect it to the house-wire running to the light fixture.
Oct 22, 2010 | Lutron D-603PH-DK Push On-Off Dimmer with...
Driver problems
Try installing service pack 3. I have found from experience that drivers that were not found with sp2 installed were suddenly located after install of sp3.
Sep 27, 2009 | Intel PRO/Wireless 3945ABG Network...
After formatting the windows we install all the drivers but audio driver always failed to install and the computer says that your hardware failed to install so what can i do
when you downloaded the driver, did it extract to a location on your c drive? if you dont know, run the installer and pay attention to what it says when it is installing,
if there wasnt a installer, boot into safemode and try installing the driver then by directing the driver installer to the location of the driver,
hope this helps
christopher aouate
Jun 13, 2009 | Intel DG31PR Motherboard
Installing VMware server on Ubuntu 8.04
try to locate vmware if you really have vmware installed via
locate vmware
if vmware was found try to find the uninstaller via
locate vmware-uninstall.pl
then execute the ./vmware-uninstall.pl
Aug 27, 2008 | Canonical Ltd. Ubuntu
Trouble with installing software for PCI FLASH Memory Dell All-in-one
First uninstall the Lexmark and unplug it from your system. Next, do a SHUT DOWN. Turn on your system, load the CD, go through the installation process, then plug in your Lexmark.
Jul 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Sanyo VPC-s500 i cant get it to install drivers or find them so i can upload pictures to my computer
The simple solution to this problem is that no drivers are required. This camera is treated as a removable (secondary) drive just as if it was a USB thumb drive or external hard drive.
First go to settings on the camera by rotating the dial to the wrench icon.
Turn the camera on and select Set-Up 2
Select USB
Select PC
Your camera is now ready to use with your computer.
Now plug your camera into your computer and check under My Computer for the drive to show. You can now copy files over to your computer from the camera.
If the drive isn't showing you'll have to go into Disk Management to view it
Disk Management is under Administrartive Tools located in your Control Panel (or Start Menu if you have it set to show there)
Select Administrative Tools
Computer Management
On the left hand side click Disk Management (or on the right click Storage then Disk Management)
Finally you can now Right Click the cameras drive and chose Open
Sep 20, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
EA Sports Cricket 07 for Windows Logo
35 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
Tony
MegaByteMe
MegaByteMe
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
