Question about Apple iPhone Smartphone
Authentication failed when sending email. Said
Authentication failed when sending email. Said user name or password incorrect. it is correct, I cannot receive or send email...what am i doing wrong? Should I start over? My iphone number was changed and it worked on the old one, but I switched phones with other phone on same account.
  • Anonymous Mar 28, 2014
    did have to change user name and password recently
Why Does User Authentication Fail When the User Logs In to the Switch from the Web System?
The possible causes are as follows:
The user name or password is incorrect.
Run the display local-user command to check whether the user exists.
Run the display local-user username user-name command to check whether the user password is correct.
There is no HTTP user access type.
Run the display local-user username user-name command to check whether the AuthMask field of the user contains H (HTTP login).
The user connected to the switch is full. The switch supports a maximum of five users.
LS S6720S 26Q EI 24S
Nov 08, 2016 | Computers & Internet
Can recieve but cant send
Unable to Send Email? Check These 5 Things - rackAID
https://www.rackaid.com/.../cannot-send-email-how-to-fix-email-sending...
This likely means SMTP authentication is not enabled. If you get a relay denied error and your password is correct, then SMTP authentications is likely not correct. Often, email users with this issue can receive but cannot send email.
I am receiving email fine, but I cannot send messages ...
www.gn.apc.org/.../i-am-rec...
Association for Progressive CommunicationsThe usual symptom is that Thunderbird will try to send for about 20 seconds before giving up with "Sending of message failed. The message could not be sent ...
Are you able to receive emails but not send? - Hostgator.com
support.hostgator.com > ... > Email > Email Troubleshooting
If you aren't able to send email, this usually means one thing: your internet provider is blocking you from using anyone's outgoing mail servers but their own. ... so that theycan monitor outgoing email on their network in order to prevent spam.
Problems Sending Mail - Receiving is Fine - InMotion Hosting
www.inmotionhosting.com > ... > Email > Email Troubleshooting
Jan 14, 2015 - Outlook 2013, cannot send mail, but can receive mail ... I haven'treceive any mail since yesterday and I can't send mails too... can you help me ...
I can receive emails but i can't send them. ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple
Jan 20, 2016 | Le Pan II 9.7" Tablet PC
Trying to add email to phone, keep batting authentication failed notice
Check that you've entered your email and password correctly. Everyone runs into this problem once in a while. :)
Jan 18, 2015 | Computers & Internet
Hi Am having kyocera 4050 b&w Copier i have problem with my scan its showing the error code is 1102 can u help me
Here is what an 1102 error is and what some of the things to look for are.. hope it helps..
1102 SMB(SMB)
Error: User/Password or SharedName/FolderNameDomain name not entered as Domain UserInput
User Name with one of the form "Domain\User", "Domain/User", "User@Domain"SMB)
User Name/Password or Shared Name/Folder Name ErrorSpecify invalid User/Password (includes unspecified)Input correct User Name/PasswordSpecify the User who is not permitted for accessing to the folderInput correct User and Password
Check access limit for send destination folderSpecify invalid Shared NameInput correct Shared Name
(See the reference for the symbol which is possible to use for Shared Name)Host Name ErrorCheck if any prohibited letter (see the reference) for Host Name is included or notSCAN TO EMAIL(SCAN TO EMAIL)
User Name/Password ErrorUser ID for Authentication is not entered/entered wrong User ID
Wrong Password for Authentication is enteredInput User ID/Password which is used for Authentication from [Advanced] on Command Center correctly
([Login User Name] on [POP3] page or [SMTP] page)
It's actually related with SMB.
The shared folder on the server may be blocked by an open ghost connection.
A restart of the samba service may repair
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Office Equipment & Supplies
DAP is asking for "authentication
This means that the file you are downloading from a site requires a Username and Password, enter the Username and Password which is used on the site which you are getting the file from.
May 10, 2011 | Computers & Internet
I cannot send mail from my iphone 4...it keeps saying the user name or password for MSN is incorrect. They are not incorrect so what can I do correct this?
1- Delete the email account from your phone and re-enter it.
2- Passwords are normally case-sensitive, make sure you are using the correct characters.
3- Log into your email account from a computer and confirm your password is correct and works.
Change your password at your computer, log in and make sure the new password works, then start with step 1 above.
Nov 02, 2010 | Apple iPhone Smartphone
When I tried to send email from Outlook, the Internet Service Provider replied -ERR [AUTH] invalid user/password. How can I correct this error?? My ISP is att.net. I have not found a solution on that...
This means that your user/password combination is wrong for that email server. So double check that you have the right password and user name entered for that account in Outlook. If you're 100% sure you have it right, then you might be using the wrong email/authentication server. If you continue to have problems and are located near Washington DC, feel free to contact me through my website.
Nov 03, 2009 | Yahoo Mail
I waana send an email on my phone. i did email setting that is email account but answerd no response whast's wrong?? just i'd like to send email with photos. could u help me. ...
Just set up email account. worked first time for me.
from menu: <messages><3 email inbox><ok><options><email accounts><ok><ok> on first account (Account 1)
fill in email account details:
Account Name: enter a arbitrary name that is relevant to you.
SMTP server: enter smtp address of your email provider
e.g. mail.isp.com.au
SMTP port: leave default of 25, unless advised otherwise by your provider
Email retrieval server type: pop or IMAP4 generally pop will work but use config as provided by isp
pop3 server: typically same as SMTP server, unless otherwise specified
POP3 port: 110 is default
use ssl checkbox. I left unchecked, this would provide a higher level of transfer security but makes config more complicated
Keep on server checkbox, I checked this as my mail emailis my laptop, so I don't wantthis to take all the messages, this way both devices can get messages, assuming leave on server is enabled on other email client on Laptop/PC but set to delete after 7 days.
My address: enter email address in the form: user@isp.com.au
user name: enter the configured email account user name. usually the name before the "@" in your email address
Password: enter password of the email account to allow access, note case senSaTive
Use SMTP authentication checkbox. i left this blank as this is not required by my isp, although some do require this.
Same as POP3/IMAP4 checkbox. only needed if SMTP authentication checkbox is set. if SMTP authentication is set then a name and password is required, generally the same as POP3 name/password entered earlier so just select - same, otherwise if isp setup requires differnt use fill the username / password fields.
<Save>
ensure newly created account has tick in the box next to it to enable it.
should work.
To send:
to test create an email message and send. may need to add email address to a contact first.
To receive emails:
<messages><email inbox><options><download> this will download any emails on your mail server
all worked well for me
best of luck
Mar 09, 2009 | Samsung SGH-J750 Cell Phone
My email won't send
contact your Internet service provider support phone number. Ask them to confirm your SMTP server name, user name and password. Also what type of Authentication settings are needed. Also check the TCP port needed for SMTP and check the firewall settings do allow the port number .
Aug 02, 2017 | Yahoo Mail
Apple iPhone Smartphone Logo
496 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
