Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a cub cadet 3185 with a PTO problem
When I first noticed the problem the blades would take a few seconds to engage then after a few times they would not engage at all.
  • carolhazelba Oct 18, 2009
    Replaced the PTO belts and that seems to have taken care of the problem. Boy what a job it was to get to them!
  • Fixitguy1 May 11, 2010
    Check the connections at the Electric clutch under the engine its connected to the crank shaft is the any noise when you turn on the Key without starting can you here the clutch engage ?? also without mower running !!! check to make sure the Blades turn freely
  • 3 Answers
Check PTO switch and look for broken wires down around the clutch itself
Posted on Dec 15, 2009
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Pto wont engage when mower is hot
Hi
your PTO is built just like a wound up coil and becomes magnatized it gets real hot and it shorts out when it heats up make sure you have no frayed wires which will creat a large risistance and really heat up
Joe
Sep 09, 2012 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
The blades run all the time on my cub cadet 1042, even if the PTO is off
If your cub has an electric pto clutch it may be fused. Or the switch is stuck on. You can check the switch with multitester to see if its energized all the time. If not the clutch is probably fused. Which is cause for replacement. Adjustment only works with clutches that wont engage.
If you pto is mechanically engaged look for obstructions in the lever pathway. Also check for stuck idler pulleys.
Be careful and good luck!
Jun 04, 2012 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
711 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
