Question about Sony NW-E003F MP3 Player
My mp4 device if i power on it it will start then
My mp4 device, if i power on it will start then within second the display will disappear but the power is still there?
For some time now i have beaning using my mp4 player and is good but recently the thing just went off when i put it on again it stated to show load and that is that without going to the main page what do i do,and is a sony mp4
Posted on Dec 28, 2009
Display not stable
the root cause of this problem is the inverter which light up the screen.you can replace the inverter or you check for shorted transistors and replace them
Jun 23, 2013 | Computers & Internet
Key on display wont start
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Apr 11, 2013 | Bosch Washing Machines
All the sudden my garmin255w is reading system software missing. help how do i fix this?
I contacted Garmin and I was given the following sequence to recover from this condition:
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Apparently this sequence will only work with the above error. I hope this assists other if they encounter this problem.Thanks for using FixYa
May 23, 2011 | Garmin nuvi 255W GPS Receiver
Hello.. i have a 376 C and when i start it it sais System Sofware missing.. and it dosent do anyting else
Hello
the "System Software Missing" problem could be solved by perform the following steps:-
If all else fails, you could always contact Garmin for help.
Good luck
Feb 15, 2011 | Garmin GPSMAP 376C GPS Receiver
How to reset the change oil light in a 2001 pontiac montana with a digital message center?
turn the key on to the power position but do not start the vehicle, then press the accelerator pedal to the floor three times within a ten second period.
Good luck dont forget to rate
Apr 01, 2009 | 2001 Pontiac Montana
No voice to Garmin Nuvi 660
In case it is a software problem try this and see if it will fix it......follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Jan 17, 2009 | Garmin Nuvi 660 GPS Receiver
No signal - stuck in Kansas
Try this and see if it fixes it for you...first disable bluetooth on your unit.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from problem.
Jan 02, 2009 | GPS
Have Garmin Nuvi 660, after a few min. I lose sats. was working fine for the last year. Just the other day it started. I was in the mountains/ bad weather so I thought that was the problem. I have update...
Try this and see if it fixes your problem...follow these steps.
Dec 24, 2008 | Garmin Nuvi 660 GPS Receiver
Acquiring satellites
Oct 19, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
Sony NW-E003F MP3 Player Logo
93 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
