Question about Braun Health & Beauty
I want to replace rechargable batt. in Braun mod. 5569u. Unsure how to access without destroying housing
    President:
  • 704 Answers
Kurt, If you are handy and can dissemble and solder, you can do this yourself, otherwise, you can send it off to a repair service that will do this for you.
If you wish to do this yourself, you'll have to take the shaver apart. There are two (2) small plastic caps on the bottom of the shaver that can be removed with a small pick or flatbladed screwdriver. Once those are out, you can unscrew the two screws that hold the shaver together and gently pry off the side panels. They have to be slid slightly down to release them from the main housing frame.
This will expose the internal circuit board and the rechargable batteries that need to be unsolded. You can then reinstall NEW rechargable batteries and solder them onto the PCB (printed circuit board). You can also purchase a complete internal PCB with the batteries and everything you need, you just swap out the electronics for the new one, although this costs about $39, while the batteries alone are much less.
Put the shell together and reinstall the retaining screws and caps and you're done. Let the shaver get a full charge before you start using it again, and it might take a couple of use and discharge cycles before the batteries will be able to take an optimal charge.
Here's a link to get the replacement batteries for your shaver. They also do the repair service, if you don't want to do it yourself.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Hope you find this Very Helpful and best regards!
Posted on Sep 25, 2009
How to sharpen Braun pulsonic blades again without replacing them? Thanks a lot.
Sorry, but there is no way to sharpen the blades. If dull, you will need to replace them
You will find replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 20, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-liion-barrery-for-pulsonic-model-shavers-p-836.html
Jan 13, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
BRAUN SHAVER MOD 7570, SHAVER NO LONGER SHAVES WELL, SHAVER MAKES A LOUD NOISE IT IS SAID I NEED A NEW MOTOR , I CAN'T FIND OUT HOW TO REPLACE IT, HOPE YOU CAN HELP.
You will find the replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
Jul 07, 2010 | Braun Syncro 7526 Electric Shaver
I need to replace batts in a Braun #5520...i donr
You will need to remove the two screw covers on the bottom of the shaver. They are on each side of the hole where the cord plugs in. Then remove the two screws to take off the bottom and you can then slide the outer case off the bottom also. You may need to change the position of the lock to get this outer case off.
You will then need to remove the black plastic back of the inner case. It snaps on so you will need to 'unsnap' it. You can then remove the circuit board for easier access to the batteries. Reassemble in reverse.
You can purchase batteries from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
be sure to read the installation note on the item page
Feb 09, 2010 | Braun Flex Integral Shaver 5520
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Health & Beauty
How do I disassemble my Braun 5561 to replace the Battery without destroying anything? Thank you for your Reply. F. Weber
I found the following fantastic We-Site who has Scematic's for for all the Braun Shavers as well as many other Products. at ""NO Charge"".
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Braun+Espresso+Master+Plus
Jun 29, 2009 | Braun Health & Beauty
Braun shaver model 5501 won't turn on anymore. chris.campanile@cox.net
You probably need to replace the rechargeable battery which dies after a few years (no longer can be recharged) like all rechargeables .
Oct 18, 2008 | Braun Syncro 7526 Electric Shaver
No power
The motor brushes may be bad. Take the screen off and turn the shaver on. Manually move the blade back and forth a bit and see if it starts to engage. If it begins to run when you do this, the brushes are worn. Braun does not make replacement motors for your shaver
Jul 11, 2017 | Braun Flex Integral 6520 Electric Shaver
Health & Beauty Logo
269 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
