Question about GE Spacemaker JVM1640SJ Microwave Oven
Heard a "POP" and both lights went out. Replaced bulbs and still, No Lights".
    Brigadier General:
  • 4,090 Answers
You most likely have a blown fuse. The fuse is located inside the case at the top and likely to the left.
Posted on Sep 24, 2009
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: night light won`t work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 20, 2009
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
JVM1340WW 003 heard pop now bottom lights do not work.
MAKE this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 01, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Light no longer works
prototech@usa.net
Jul 20, 2009 | Kenmore 80809 Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Night light won`t work.Was changing bulb and heard a pop.Replaced bulb,still won`t work.
William E. Miller
prototech@usa.net
Sep 14, 2008 | Kenmore 62702 Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
