Question about Cell Phones
Why does the vibrate function not work on my samsung tocco
Could you tell me how to turn off keypad tones when texting on a samsung Tocco
Adjust the volume of the key tones
In Idle mode, press [up /down] and adjust the key tone
volume.
Adjust the vibration intensity on the
touch screen
You can adjust the intensity of the vibration when you
tap the phone screen.
1. In Idle mode, press [up /down].
2. Select Vibration and adjust the intensity of the
vibration.
Jan 13, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
Hello, i have the samsung tocco lite, i changed my silent profile vibration to the max as i never feel it go off when in my pocket, but ever scince then my whole phone vibrates everytime i touch it even...
press the volume down button on the left side of the phine and a menu will pop up at the top o the menu you can click on "vibration" set it to 0 and touch vibrations will stop
Oct 06, 2010 | Samsung Cell Phones
The vibration is not working on my samsung tocco lite
This problem has something to do with the program or software. The program is not working correctly, that is why it cannot send a command for the vibrate to work.
You need to contact the manufacturer, and have them upgrade the firmware.
Mar 14, 2010 | Samsung Tocco Ultra Cell Phone
Touch screen stopped working
my touch screen stoped working i can still use all keys also i feel vibrate when touch the screen
helppp
Mar 07, 2010 | Samsung Tocco Ultra Cell Phone
Alarm sound
:-) that is the way the Samsung phone is designed for silent mode:-)
Aug 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i get my samsung tocco lite to vibrate when all the vibation settings are on?
You will have to replace the motor. It is just a small DC motor with an eccentric weight causing the vibration when it spins. They do fail sometimes and I believe that you have adjusted your settings properly for vibrate mode. If replacing the motor does not work then there is an issue with the firmware or motor drive circuit. You can check the operation of the motor by hooking it up to a 1.5 V cell. Polarity is not an issue. It should spin. If it does not then we are pretty sure that replace it will solve this problem. Go to HowardForum.com to get disassembly instructions for your phone. You will need a soldering iron and may need a T6 Torx screwdriver available at Sears for about $4.00. Best of luck with your repair. Please rate me if you find this helpful. Thanks for letting me serve you on Fixya.
Jul 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Help
press dial, then press and hold the # (hash) key. This will select silent. Repeat to undo.
Jul 16, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung tocco lite touch screen..
this is a factory fault that cannot be rectified, from time to time the phone will freeze and after a while will function normally as if nothing ever happened. leave the phone alone dont fiddle with it until it resumes normal function
Jul 13, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Cannot use Vibration alert
sir...
open your phone, just follow the instructions...
but pls be careful... it might kill your phone..
just follow the link and watch the video on http://www.wonderhowto.com/search/dismantle-f480/
clean the contacts between the ******** and the board..
tnx
Feb 03, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Vibration
Go to "settings"
"Phone Profiles"
For each profile, you can set the Call Alert Vibration level and save it.
Hope that helps.
Jan 25, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Cell Phones Logo
112 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
