Question about Cannondale Cycling
Will not shift from 2 to 3 on left. Trigger pulls
Will not shift from 2 to 3 on left. Trigger pulls in and is very loose
  • 67 Answers
The cable is lossened at the shifterbar.
Posted on Sep 24, 2009
How do you reset all family settings on xbox 360
There are different codes for different 360 consoles and different dash versions:
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system info box comes up SCROLL TOP THE BOTTOM and type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in and hold it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
!!!HERE ARE MORE CODES THAT HAVE BEEN TESTED AND WORK!!!
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER (Do this twice)
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, X, X, UP, DOWN, DOWN. Then down, down again.
Left Trigger, Right trigger, X, Y, Left Bumper, Right Bumper, DOWN (dpad), Y, Left, Left
Jun 22, 2014 | Microsoft Xbox 360 Console
Hayter problems
if it has the green trigger you pull up to move height adjuster it is common that they snap or the roll pin comes out. simply take out the 2 cross head scews from the handle and remove handle, the trigger will then be free to remove, there will be a compression spring on the trigger dont loose it!!!! the triggers are quite cheap and can be bought online at ebay etc, just slide trigger back into handle bot forgetting to reit spring. refit handle to chassis and refit the 2 screws
May 22, 2014 | Garden
Cannot get 5th and reverse gear. Feels like neutral. 1, 2, 3 and 4 work fine.
the linkage is loose or poping out! check to c if trans is tightend down
Aug 22, 2012 | 1995 Dodge Neon
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
1990 Porsche 911 Carerra 2 Targa (964)...car was shifing fine...now is stuck in second gear. Clutch will engage...but no other gear is selectable. ...no strange noises...just will not...
YEP SHIFT LINKAGE LOOSE OR WORN NEED ADJUSTMENT.ADJUST THE SHIFT LINKAGE BY POSITION THE SHIFT LEVER IN NEUTRAL .REMOVE THE REAR TUNNEL COVER IN FRONT OF THE REAR SEAT.PULL THE RUBBER DUST COVER FORWARD ON THE SHIFT ROD.LOOSEN THE CLAMP BOLT ON THE SHIFT ROD.MOVE THE TRANSMISSION SELECTOR SHAFT ALL THE ITS LEFT STOP,KEEPING IT IN NEUTRAL.WITH THE TRANSMISSION STILL IN NEUTRAL . MOVE THE GEARSHIFT ROD TO THE RIGHT TO ITS STOP.TIGHTEN THE CLAMP BOLT TO 18 FT LBS.TEST THE SHIFT LEVER PLAY SHOULD BE THE SAME IN ALL GEARS IN ALL DIRECTIONS.
Apr 18, 2011 | 1990 Porsche 911 Carrera
How do I sight-in(zero-in) my handgun(S&W Sigma Series 40 cal.) Factory issue sights, aiming center mass hitting target bottom left.
The problem with this is, the Sigma comes with Fixed Rear Sites. Non Adjustable.
I also have a good buddy of mine that was in the Police Academy who bought that gun for his duty weapon and was having the same problems you are. Hitting Way Low.
Now, another side to this problem Ive heard of is that the Sigma Series has a really heavy trigger pull. And a lot of shooters (More than 20) have come together with the fact that due to the heavy pull, it causes you to pull the muzzle downward as you squeeze the trigger...without even knowing it. Causing you to hit low.
If this is the case, I would take a guess that if you are a left handed shooter, you have too much finger on the trigger causing you to pull left...mixed with the heavy trigger pull, forcing downward. Or a Right handed shooter with the correct amount of finger on the trigger, but such a heavy pull, your pushing to the left. Just another thought for ya.
But from what my research has led me to find, there is no option yet for adjustable rear sites.
Here is a LINK to a website discussing the heavy Trigger Pull causing dropped Bullet Impacts. Read what they say and it might help ya. If you change some things, let me know. Id be interested to hear if it changes your POI. (Point of Impact)
Hope This Helps!
Oct 17, 2009 | Sport & Outdoor - Others
2004 Mercury Monterey tail gate handle came completely off. The left side's guide is in place, but the right side is retracted - hence can't just put it back in. Any ideas?
Open tail gate. Use the access square inside - pull cable to open tail gate. Remove interier panel - 2 bolts plus 2 screws (2 bolts on handle and 1 screw each side), pull remainder out of guide clips. Now have full access to locking mechanism. Identified a retaining spring had come loose sending guides to shift left (exterior point of view). Place hand in tail gate and move guides over and put spring in place to retain. verify it works and put back together. Handle is the trickiest part as the bolts have to go through the interior panel and afix to the metal tail gate.
Sep 20, 2009 | 2004 Ford Freestar
Trigger problems
I have repaird hundreds of nail guns with a problem similar to yours. Depending on the brand and model, the problem can be repaired by checking the following. Headvalve orings should be checked for wear and any surface that the orings contact must be smooth and free from scratches. If the surfaces are scratched try to smooth with fine sandpaper and use light grease instead of oil when assembling. The safety contact foot may not be reaching high enough into the trigger to properly push in the trigger button. Check for worn spots on the trigger that may be filled in with epoxy, loose fitting trigger caused by worn roll pin or retaining pin. Some of the trigger valves as used on many bostitch nailers (tva6 valve) used a plastic pin which contacts the trigger. If this pin is loose or worn the valve should be replaced. Some tva6 valves have a vinyl looking sort of oring that fits too loose on the spool. This vinyl oring in not available by itself but if the oring fits too loose the gun will not fire and leak air. On bostitch remove the trigger and the rollpins holding the trigger valve and apply air to gun to eject valve. (use heavy glove to catch valve as it will come out with force)
Sep 26, 2008 | Stanley Bostitch BT200K
Leaking from left wheel when applying trigger onmodel 7901
Sounds like a problem with the left spray nozzle, may be out of place. Either that or a line is loose and leaking. Either way you will have to pull the top housing off to check it over.
Feb 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Entering cheat odes
Cheat CodesUnlock All Levels:
From the Mission Select screen, enter code: Y, RB, Y, RB, X
Full Health:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: LB(2), RB, X, RB, Y
Unlimited Ammo:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: RB(2), LB, X, LB, Y
Scott Mitchell Invincibility:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: Y(2), X, RB, X, LB
Team Invincibility:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: X(2), Y, RB, Y, LB
Nov 29, 2007 | Microsoft Xbox 360 Console
Cycling Logo
78 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
