Question about NetGear RangeMax WPN824 Router
Windows XP SP2 does not ask for network key
Internet connection is fine with PC, but when connecting to my network the netbook is not asked for the network key.
    Sergeant:
  • 191 Answers
Please check that netbook may have key already written on drive and supplies it auto, if not check router authorization/acces settings and modify accordingly
Posted on Sep 24, 2009
I bought the new sylvania 7" laptop. I am having problems.. We have connected to our wireless router however, we not get on the internet...
from another computer, go to the routers configuration screen and make sure the status shows that it is connected to the internet. Also the routers internal LanIP address must be 192.168.1.1 for the netbook to work.
Sep 19, 2010 | Sylvania G-Netbook
I have installed windows xp sp2 into my hp compaq dx2300 microtower, but i am asked to activate over the internet or call microsoft representative for an istallation ID. the computer is failing to activate...
Check your Ethernet device in device manager option. Click on the "Network adapter" option in device manager. Now re-install with your motherboard installation disc or click on "Update driver" option, it will automatically run and fix your problem.
Jul 19, 2010 | HP Compaq dx2300 Microtower - RT950UTABA...
Windows XP sp2, Router speedstream 6520 Wireless setup problem. The netbook is not asked for the network key. ''Windows is unable to connect to the selected network....... I get this message even if the...
please check router settings [transmission mode ] set it to G and try again, if all fails reset router to factory and reconfigure with is a safest thing to do.
Sep 24, 2009 | Computers & Internet
I cannot get my Netbook to connect to my wireless network. I have 3 other devices that connect just fine. What am I doing wrong?
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Sep 24, 2009 | HP Mini 1000 Netbook
Wired internet working through netgear... wireless access denied
You must determine the wireless security of your router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
a. Click on the Wireless Settings under Setup.
b. take note of the SSID
c. if your using WEP...the network key would be on the key 1.
d. If WPA-PSK TKIP is in use just type in a new key with a minimum of 8 characters on the passphrase box. Please remember it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Apr 06, 2009 | NetGear WGR614 54Mbps Wireless Router...
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
No connectivity after.....
If you have installed Windows XP Service Pack 2 and are experiencing any of the following symptoms, this bug is affecting your system.
After installing Windows XP SP2, your network connection reports a problem with "Limited or No Connectivity"
You have trouble connecting to the Internet or your local area network after installing Windows XP Service Pack 2.
Your network connection gets stuck "Acquiring IP Address"
Oct 18, 2008 | Computers & Internet
I cannot creat a wireless network
What OS are you running? If XP:
There are two ways to configure your wireless router: using Windows Connect Now and manually.
• If you don't have a router that supports Windows Connect Now, you need to manually configure your router:
1.
Using the network cable that came with your wireless router, temporarily connect your computer to one of the wired network ports on your wireless router (any port that isnt labeled Internet, WAN, or WLAN).
2.
Turn your computer on; it will automatically connect to your router.
3.
Open Microsoft Internet Explorer and type in the address to configure your router, as described in your router's instruction manual.
4.
Create a password if a prompt appears. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
Here is the general login user and passwords
3Com
http://192.168.1.1
admin
Admin
D-Link
http://192.168.0.1
admin
(leave blank)
Linksys
http://192.168.1.1
admin
Admin
Netgear
http://192.168.0.1
admin
password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three items:
Set your wireless network name (known as the SSID) to something unique that does not identify your name or address.
Enable Wi-Fi Protected Access 2 (WPA2) encryption to help prevent uninvited guests from connecting to your wireless network.
Note: We don't recommend using WEP. WPA-2 is more secure. If you try WPA-2 and it doesn’t work, we recommend that you upgrade your network adapter to one that works with WPA-2.
Set your administrative password to prevent others from configuring your router.
The exact steps you follow will vary depending on the type of router you have. After each configuration setting (SSID, WEP, and administrative password), be sure you click Save Settings, Apply, or OK to save your changes.
Note: The pictures in this section show Linksys wireless equipment. Equipment from other manufacturers will vary in appearance. For example, to save your settings in Linksys, you click Save Settings. Other equipment may have a different display, and you may have to click Apply or OK.
SSID or naming your networkA service set identifier, or SSID, identifies your network. Choose a unique name that you're confident none of your neighbors will use, but don't specify your name or your address. This is not a security tool, so you don't need to make the SSID complex.
Help prevent uninvited guests from connecting to your wireless network. To learn how, read Implement WPA2-Personal wireless security on a Windows XP SP2-based computer.
Administrative passwordThe last configuration change you should make is to the administrative password. Just like any other password, the administrative password should not be a word you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
Connect your computers and devicesIf your computer does not have wireless network support built in, you can install a wired or a wireless network adapter. Windows XP will automatically detect the new adapter and might prompt you to insert the CD that came with it. The on-screen instructions will guide you through the configuration process.
Windows XP Service Pack 2 (SP2) is not required for wireless networking, but it does make setting one up much easier. SP2 also helps protect you against viruses, worms, and other Internet intruders. To install SP2, visit Microsoft Update. The steps below apply only if you're using SP2. Windows XP will show an icon with a notification that says it has found wireless networks.
To connect your computer to your wireless network
1.
Right-click the wireless network icon in the lower right corner of your screen, and then click View Available Wireless Networks
2.
The Wireless Network Connection window appears and displays your wireless network listed with the SSID you chose. If you don't see your network, click Refresh network list in the upper left corner. Click your network, and then click Connect in the lower right corner.
3. Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
Windows XP will show its progress as it connects to your network. If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key—click Cancel and return to step 3.
After you're connected, you can close the Wireless Network Connection window. Now you're ready to browse the Web wirelessly. You can also create a wireless network in your home that connects your computers, printers, cameras, games, and other accessories for easy access and enjoyment.
Apr 21, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Can't connect DB 102 ADSL modem
Dear kcpau
You need to set the internet connection manually on Windows Me. Go to Control Pannel, select Network connections and follow options to select LAN settings. You might need someone to walk you through the steps.
Consider upgrading your ME to XP; Windows ME is unstable on networks and may trouble you to drinking. It is ultimately best. If you start upgrading it, XP will automatically put on the internet if you have your IP addresses already set, or will ask you to punch in IP addresses at the end, then you are done.
Good luck.
Nov 06, 2007 | Acer ALW 3016 Networking Switch
NetGear RangeMax WPN824 Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
