Question about Toshiba TEC B-SX4 Thermal Label Printer
Error message is printer jam -it is a new stock we have changed to a synthetic removable adhesive. do you suggest to recaliber How do I recaliber to the new liner and new label stock? Thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Go to sensor adjustment and fiollow the instructions.
When the right sensor is selected press feed or restart for 5 seconds (i.e until a little star is displayed next to the value)
Posted on Jan 14, 2014
2 Suggested Answers
  • 19 Answers
SOURCE: paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Posted on Jan 25, 2010
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Printer says paper jam, but there is no jam. Everytime it is to print, the alarm light comes on and says to remove paper jam. No jam is there!
Printers use either small 'flags' to detect paper presence or passage or a photo-optical interrupter. The first can be damaged by a previous jam and the latter can fail.
If you have ever used label stock or another adhesive-treated stock, you may have residue from these and without disassembling the printer, you won't be able to determine the exact cause of the erroneous paper-jam error.
Do a search on your brand and model to see if there is a site or tech with specific knowledge of your printer.
Jan 20, 2011 | Canon Pixma MP450 All-In-One InkJet...
It said to open from cover and remove paper I did and It dont work
If you receive an "Open front cover" error message the solution is to open the cover and remove the paper and any remnants of the paper jam. If there is no obvious paper remnants jamming the printer and you continue to receive an error message I would suggest unplugging the printer from the power source.
After 5 - 10 minutes plug in to power source.
Turn on printer.
See if this has resolved error message. If not you will need to check more carefully for paper remnants that would be causing the printer to detect a jam.
Trust this is helpful. :)
Dec 08, 2010 | Konica Minolta PagePro 1390MF All-In-One...
Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
I need help repairing my HP Deskjet 5110xi all-in-one
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | HP OfficeJet 5110 All-In-One InkJet...
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
"Unable To Change" message. Tried all suggested fixes none work. Can you provide any additional help beyond the standard fixes. Nothing is jammed, turning it off for even days doesn't remove the error...
press menu then start bk copy then fourtimes arrow up. what error code does the machine display?
In case you have an error 50 you have to open the printer cover and to reinsert the encoder strip which is out of position into the ph. This occurs sometimes after a serious paper jam.
search error 50 for dcp 110, 115 or mfc 210 here. its the same procedure.
Dec 17, 2007 | Brother MFC-5840CN All-In-One InkJet...
HP Laserjet 1020: False paper jam
Hp false paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 25, 2007 | Office Equipment & Supplies
Toshiba TEC B-SX4 Thermal Label Printer Logo
47 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
